#10-32 screw in place of an M5
I have a block that has an M5 thread in it. We don't carry M5 screw's so I was told to use a#10-32 screw which has a slightly smaller thread but will screw in but feels a little loose. This just feels wrong to me. Am I being overly paranoid or is this a bad idea?
RE: #10-32 screw in place of an M5
Bad idea!
Thanks for your responce
We do use LOCTITE on every fastener.
Home Depot, Ace hardware, Lowes, Tractor Supply Hardware, Fastenal, Grainger not available?
This is MOT a valid solution, and will, if repeated, get you in trouble in the long run. Fix it properly with an M5 threaded fastener.
Thats my way of thinking also. Thanks all for your comments.
Ditto here. Bad idea. Metric hardware is available all over!
Tunalover
