No Roadway Entry Found Error (InRoads)
I keep on receiving this "No Roadway Entry Found" error when I try to run the roadway modeler in InRoads.  I have the correct horizontal and vertical alignments and existing surface activated.  Also, I have the right template (.tml) and roadway (.rwl) files activated.  I ran this one time and didn't receive this error but I had the wrong template and roadway files activated.  I tried running it again with the correct files and I get the error message.  I tried closing out of the drawing and coming back in but that didn't work.  My roadway file is set-up correctly with the templates and stations so I know it is not that.  What do I do?  Please respond.
RE: No Roadway Entry Found Error (InRoads)
Make sure your horizontal, vertical, superelevation stations are all within the required modeler run. Sometimes they seem to be but are not due to rounding issues with Microstation and InRoads. Try also to move up your beginning station by .01
