ASME Code for Air receivers
Morning All,
I'm new to ASME Code and someone is asking me "what design code he can stamp on the data plate" for a new Air receiver they did.
These are built with 18" pipe and cap ends...also 2" and 1/2" 3000# Nozzles...Working Pressure 150psig.
Is there anyone who can help me on this.
Best regards
Akn
Best regards
Akn
RE: ASME Code for Air receivers
This actually sounds like it is a bit of pipe and hence not a pressure vessel, so ASME B 31.3 would be a good start point.
Mike
In which case, stamping it to Section VIII is going to be virtually impossible. Though this probably would be a vessel (even though fabricated of piping components), in some overseas jurisdictions and with a client who doesn't care one may be able to call it a pipe.
Cheers,
John
Best regards - Al
Which is the code for vessel design, fabrication and testing/inspection that is the code to be stamped on vessel nameplate.
