Ploting variable thickness
Hi all
I am trying to model a shell with variable thicknes by means of an analytical field.
First of all i dont know if I am doing it properly, (I created a variable analytical field and I assigned it to the thickness of a section)
When I try to plot the thickness of the shell I can see no thickness so...
is this possible?
how could I check that each element gets the proper thickness?
thanks a lot
n3l3
is this possible?
thanks a lot
n3l3
RE: Ploting variable thickness
(which is wrong in every way)
the problem is that when doing that no thickness apears for the elements with the analytical thickness
Once that I run the job I get the variable so I can check the thickness.
thanks all
I'm facing the exact same problem.
What do you call STH variable please?
Could you post a screenshot of your parameters so I can get the inspiration please?
Thx
