port size of nordstrom plug valve, figure 4749
does anyone know the port size of a nordstrom figure 4749 (% of nominal pipe size)? I calculating flow through an existing valve and my value is barely too small when I use standard 40% assumption for plug valves. I'm thinking that the actual port size is larger, but I can't find it in any documentation have.
RE: port size of nordstrom plug valve, figure 4749
Why don't you just go to the Nordstrom website and do some research and them contact them if you do not find your answer?
http://www.google.com/url?sa=t&rct=j&q=&am...
prognosis: Lead or Lag
