AWS d 1.4
AWS d 1.4
I have to help client put a WPS together for lap splice of # 11 bar , looking @ para. 3.6 "Lap Joints" reqs. dbl flare V groove welds (fig 3.4 (A) , except that a single flare V groove may be used if accessible from one side only , and approved by Eng.
Para . 3.6.2 also show a indirect lap splice with a splice plate,
My ? I don't see a fig. associated with the single flare V groove option , as we'er faced with that issue.it would seem to me that the single flare V groove weld option would req. a larger flare weld but maybe not
RE: AWS d 1.4
3.4 (B) is an alternative for 3.4(A.
An alternative to the above would be a bar coupler either in lap position of direct position. The bar can either be threaded or lock screws Lenton from Erico is one maker.
