Reference set question
I'm using NX 7.5.
I added an existing component to an assembly. I don't have write access to the component (don't know if that makes a differnce). The component has 4 reference sets to be used depending on the application. After I added the component with the desired reference set selected, I saved the assembly and closed it. When I reopened the assembly the component opened up another (undesired) reference set. Is there anyway to reopen the assembly and component with the desired reference set without going to the trouble of changing my load options?....Thanks
