Must have technical references for new engineers
First post on the board, though I've used it for technical info many times.
I'm working on a blog post for must have technical references for new/young engineers. I'd love to get some feedback; specifically other disciplines. For me:
Discipline: Mechanical/Piping
Reference: Crane Flow of Fluids, Technical Paper #410
Why: I use it at least twice a week. For such a small book it has about everything you need for simple pipe sizing calculations. It has fluid properties, pressure loss info for typical fittings, and of course my favorite table "Flow of Water through a Schedule 40 Steel Pipe".
Kevin Connolly, PE
www.TheEngineeringSurvivalGuide.com]
RE: Must have technical references for new engineers
Type "engineering resources" into the search function for the full site and you will find a lot of the information you are looking for.
GPSA Field data book. Cameron Hydraulics. I rarely need anything else, but no library is complete without Mark's because there always stuff just beyond the Reader's Digest Condensed Engineering that is Crane, Cameron, and GPSA. When I look at my 100 linear ft of bookshelves, I notice that my college Chemistry book comes off the shelf more than most (it seems to get used a lot more than my copy of Perry's).
David Simpson, PE
MuleShoe Engineering
Law is the common force organized to act as an obstacle of injustice Frédéric Bastiat
Machinery's Handbook. I wish I had purchased one of those immediately after I received my diploma. Chock-full of practical information that goes beyond the theory taught in the university. For the amount of usefulness stuffed into that book, the price is a bargain.
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
Cameron's Hydraulic data has been my "go to" for over 35 years.
Build a good, comprehensive library. Invaluable.
Hazen Williams Hydraulic Tables, I use the 3rd edition, 11th printing
USBR Design of Small Dams
USBR Design of Small Canal Structures
USBR EM 25 Hydraulic Design of Stilling Basins and Energy Dissipaters
AISC Steel Construction Manual 8th Edition (red) and also latest edition
ACI 318 - latest edition
VT Chow, Open Channel Hydraulics
Brater and King, Handbook of Hydraulics
For ChemE, a copy of Perry's covers a lot of ground. Some other texts I frequently use:
Elementary Principles of Chemical Processes by Felder and Rousseau - an intro text, but it has a lot of useful tables and is MUCH lighter than Perry's.
A good fluid/heat/mass transfer book or books. I use Welty, Wicks, Wilson and Rorrer's Fundamentals of Momentum, Heat and Mass Transfer because it combines all three.
A CRC handbook can be good for chemical properties, but is not absolutely necessary.
Crane Technical Paper 410 has been useful for me when reviewing relief valves.
A good statistics reference, particularly if you are involved with process control/improvement.
Also, references for the particular field you are in. For example, if you are in petro/refinery, you should probably have a separations reference for column work.
Hope it helps.
Matt
Quality, quantity, cost. Pick two.
The most-thumbed references on my shelf include
Roark's Formulas of Stress and Strain
Parker O-ring Handbook
used to have Crane 410, but gave it away to a needful youngster.
I'm in electronic packaging.
My favorites are:
Marks' Standard Handbook for Mechanical Engineers
Roark's Formulas for Stress and Strain
Cooling Techniques for Electronic Equipment (D.S. Steinberg)
Vibration Analysis for Electronic Equipment (D.S. Steinberg)
Parker O-Ring Handbook
Ryersen catalog
Beth Steel catalog
The Y14 ASME drawing standards
The Genium Publishing Drafting Room Manual
BTW MatthewL: Welty, Wicks, Wilson and Rorrer's Fundamentals of Momentum, Heat and Mass Transfer book got poor reviews on Amazon.com due to a high number of errors. Sounds like it would be a good resource if it were better proofread!
Tunalover
For Civil,
Standard Plans for Public Works Construction
ADA Standards for Accessible Design
B+W Engineering and Design
Los Angeles Civil Engineer and Structural Engineer
http://bwengr.com
I assume that is the green book? It is useful in California, less so in other parts of the country.
add AASHTO Materials Part 1 Specifications and Part 2 Tests
Like MatthewL, I have a copy of Felder and Rousseau I use frequently.
I also recommend Lange's Handbook of Chemistry.
For the Project Engineer, I recommend:
Planning, Estimating, and Control of Chemical Construction Projects by Navarette and Cole (get the 2nd edition, not the 1st, which was solely by Navarette)
Industrial Megaprojects by Merrow. This is not hard reference, and is in fact very conversational, but as a study of over 300 chemical industry megaprojects, it is sobering, enlightening, and accurate. I recommend it highly.
