generate echo with convolution and cancel it
hello guys
i am beginner at using matlab
i want to generate echo on a sound file i recorded in wav and then made echo on it with convolution method.
and the second part cancel the echo
i dont know how to do it in matlab , i know formulas only .
any help i will be thankful
thx
RE: generate echo with convolution and cancel it
thx :)
i have this code for do echo:
CODE --> matlab
%working code for echo in conv
[y,Fs]=wavread('C:\Users\Mohamed\Documents\mohamed\pop.wav');
x = zeros(1000,1);
x(1) = 1;
x(1000)=1;
z= conv(x,y);
sound (z,Fs);
i want remove the echo from the sound and get back original sound but with using convolution method only??!!
i tried this method
CODE --> matlab
%cancelling
N=25199; % delay in samples
y=z; % Signal with echo
x(1:N)=y(1:N); % First N samples of x and y agree
for i=N+2:length(y)
x(i)=y(i)-0.75*x(i-N); % Inverse filtering
end
subplot(211)
plot(y); % Plot signal with echo
title('SIGNAL WITH ECHO');
subplot(212)
plot(x); % Plot signal without echo
title('SIGNAL WITHOUT ECHO');
soundsc(y); % Listen to signal with echo
soundsc(x); % Listen to signal without echo
x sound only same as echo one and when reduce N samples to less .... there is echo come over the original one
any help plz??!!!
yeah , it a project
i have a work code for cancel the echo:
CODE --> matlab
l=max([length(z);length(x)]);
a=fft([z;zeros(l-length(z),1)]);
b=fft([x;zeros(l-length(x),1)]);
c=real(ifft(a./b));
sound(c,Fs);
it works fine , but they want me use conv function to remove echo , i dont know how :\
