Rubber Expansion Joint
Hi all,
I have performed a stress analysis of a progressive cavity pump skid. The allowable loads of the pump are very low (about 500N in all directions). We have ordered rubber expansion joints for the suction and discharge of the pump. The problem is that the thrust force of the joint exceed considerably the allowable load. the supplier has proposed expansion joints with rods. Is this enough to control the thrust forces.
Thanks!
RE: Rubber Expansion Joint
Yes... if they are suitably designed for the pressure thrust.
Beware a few more things:
1) What happens to the pressure thrust if the joint compresses off the tie rod nut?
2) The pump always sees some pressure thrust. What pressure thrust does the joint add?
The joint pressure thrust is about 1100N i have asked an expert and he says that this force shall be taken by pumps anchor bolts. axial movement has been stopped by a support just before the expansion joint. The expansion joint size is 5" and the pressure is 6bar.
