Hinge load - pressure only
Hi everyone!
I have one question about hinge load. I want to create some pressure only elements in the center of the hinge like on the attached photo (photo is not from FEMAP, but it represents my intentions).
If anyone could help me, I'll be really grateful.
Thank you.
http://files.engineering.com/getfile.aspx?folder=6...
Thank you.
RE: Hinge load - pressure only
i think you're trying to apply a bolt load into the two lugs. you can do this using an RBE "spider" element connecting the bolt to the lugs. possibly you could add gap elements, between the RBE and the lugs.
possibly easier is to model the bolt as a solid (or tube) and avoid the RBE ... why model the shaft as a 1D beam element ?
Quando Omni Flunkus Moritati
Thank you.
You have two way to create Spider elements :
1/ Go to Model / Element, under Type choose Rigid and hit ok. Define your Master node (always 6dof) and slave nodes with the desired Degree of Freedom.
2/ Under Custom tools / Meshing, you can choose several method to create a RBE2 (spider) :
- from nodes, then you have to select all nodes around the bolt holes and then Femap will automatically create a spider with a master node defined in the center.
- from curves, then you have to select two curves which contain nodes on it and then Femap will create a spider following the same principle as previously
- from surface
Note that for the three method the RBE2 slave nodes will have only 3DOF.
Play a bit with those command and you will better understand how to create RBE2, it is really not difficult.
SN
