Re: Partial Section Cut in Assembly (NX 8)
Here's on of the previous message of John Backer, regarding the topic of this subject:
" JohnRBaker (Mechanical)
23 Sep 11 11:55
This can be simulated using the Assembly Cut functionality but that will actually modify, at the assembly level anyway, the components of the assembly.
However, as part of the PMI module's functionality, there is a Model Sectioning function which will allow you create arbitrary cutting planes, select which components are to be sectioned or not, and it creates this all as a view-dependent operation so that you can see the model sectioned or non-sectioned (or even multiple-sectioning scenarios) by just switching between different Modeling views.
Here's an example of what can be done using the PMI SectioningZ":
Unfortunately, the John baker's example is not present anymore.
I'm interested in creating a Model Sectioning of an Assembly in PMI, identical with Mr. Baker's solution.
But I can't find "Model Sectioning"....................!
23 Sep 11 11:55
MZ7DYJ
RE: Re: Partial Section Cut in Assembly (NX 8)
Start -> PMI
Attached is an simple Assembly with a PMI Section stored in the view named 'SECTION OF TFR-TRI'. If you wish to see how the section was created, just go to the Part Navigator, expand the list of 'Model Views' and double-click the above named view. If you wish to create a new 'Section View', change to another view (you can only section a model view once), activate the PMI toolbar and select the 'Section View...' icon.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I can't believe I was so ignorant about the PMI functionality!!!!!!!!
How could I get more abilities/knowledge/familiarity from the PMI functionality?
MZ7DYJ
MZ7DYJ
www.nxjournaling.com
MZ7DYJ
What "multiple-sectioning scenarios" would mean in this context?
MZ7DYJ
To see what I mean, I've attached a new version of the Valve Assembly that I posted previously. Now this is just the single assembly file, the rest of the parts that you have are OK, just place this new file in the same folder where those others part files are and open it. Once it's open, go to the Part Navigator and expand the 'Model Views' item and note the there are now THREE different 'Section' views. Just double-click them one at a time to see three different section views of the same assembly, keeping in mind that if you double-click the (Work) view it will take you into the 'Section View' editor.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you Mr. Baker!
Today I had the opportunity to apply the Section View (PMI).
It looks much better (and easier) than using Assembly Cut or regular Boolean features.
No geometry modification.......Clean, nice!
MZ7DYJ
A classic example is driiling a hole for a pin that's driven into two parts to assure that they won't move once assembled. The hole needed for something like this can only be drilled at assembly AFTER the parts are actually assembled and while the hole would not appear in the models used to manufacture to parts, once they are part of the assembly and if you were disassemble the parts the holes would be there, but only because they were part of the assembly when the hole was drilled. If you look at that Valve Assembly I've provided you you'll notice that the Jam Nut is cross-drilled and if I wanted to assure that once assembled, that you couldn't easily disassemble this item you could use Assembly Cut to show the hole drilled through the shaft where a roll-pin would be driven in to lock it down. Now that hole, while it's reasonable to expect to see it in the Jam Nut before the valve was assembled, you wouldn't have expected to see the hole in the shaft. No, if can only come after the parts had been assembled otherwise there is very little chance that any sort of pre-drilled hole would have lined-up with the cross-drilled hole in the Jam Nut. Due to tolerances and the exact start point of the threads in both the Jam Nut and on the end of shaft, you could have never included the hole at the time that shaft was being fabricated, it could only come by being drilled on the assembly floor.
Anyway, I hope this clears-up the uses of these two very different functions, Assembly Cut and the PMI Section View.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
The difference is clear blue.
The practical examples were very helpful for comprehension.
MZ7DYJ
I was wondering if it is possible to use in the "valve_assy_PMI_Multi-Sectioned.prt" example the other PMI option for sectioning - "LIGHT WEIGHT SECTION VIEW", getting the same section profile like the other PMI option :Section View.
MZ7DYJ
I was wondering if it is possible to use in the "valve_assy_PMI_Multi-Sectioned.prt" example, the other PMI option for sectioning: the "LIGHT WEIGHT SECTION VIEW", getting the same section profile like the other PMI option :Section View maybe by (using the "BOX" choice).
MZ7DYJ
However, the examples where I REMOVED only a quadrant or an octant of the model, those are not possible as the 'Lighweight' approach uses one or more infinite planes to 'visually trim away' the model, therefore, by definition, all of the results are convex in nature. Concave results, like my quadrant/octant removal, is something the the current 'PMI Section View' is capable of doing, just that it's 'heavyweight' in the sense that it relies on actually performing view-dependent Boolean operations on albeit lightweight copies of the components, but still they're copies and modeling operations are involved whereas the 'Lightweight' approach is being done using what's in essence a visual trimming of the model, just that it's only acting on a selected set of components and not the entire model, which is what happens when you use the traditional 'Clip Section' viewing function, which is similar in terms of the User Interface and the cutting plane manipulation tools.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
MZ7DYJ
I’ve noticed a ‘Crosshatch” icon (under Settings → Wireframe Appearance), but I do not its effect yet…
Any thoughts about this?
MZ7DYJ
Note that in the image above I asked that NX assign the 'Crosshatch' patterns based on the Material of the various components (you still have the option to use a 'General Use' pattern if you wish) where in this Assembly the Arm is Aluminum, the Cover plate is Steel and the Valve Body is Iron.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I can't wait to get my hands on NX9........
MZ7DYJ
