Smooth transition from line to arc
I want to draw in a sketch, a smooth transition from a straight line to an arc using a clothoid / euler curve, any advice appreciated.
RE: Smooth transition from line to arc
Why not just make the arc tangent to the line?
Hi. It is tangential, but this gives a stepped acceleration at the point of change
Use a spline and add equal curvature constraints to each end.
Use a Spline, Style Spline or Conic with Equal Curvature contraints.
Anna Wood
SW2014 SP2, Windows 7 x64
