Saving configurations as different file assemblies
Hello all,
I am having several configurations of the same assembly generated via design tables. While trying to export my configurations to ABAQUS, only the default one is always being exported.
Is there a way to solve this issue or if not, is there a way to save each configuration in separate files?
Thanks again!
Thanks again!
RE: Saving configurations as different file assemblies
Open each copy & delete the unwanted configs.
If you have to do this often to other assys, a macro would be more efficient.
