Stiffness and Allowable Loads for API 650 Flush-Type Shell Connection
Hi all
My refinery is constructing two new API 650 storage tanks of 44m and 47.5m diameters. Both of them have at least one flush-type shell connection per section 5.7.8 of API 650.
We are trying to determine the stiffness coefficients and allowable loads for these nozzles. Annex P within API 650 outlines the method for checking nozzles conforming to Table 5.6a and Table 5.6b, i.e. having L/2a (as shown in Figures 5.2) of at least 1.0., but flush-type shell connection doesn't meet the minimum elevation requirement per Table 5.6a/b. We therefore concluded that Annex P is probably not the appropriate reference for finding out the stiffness coefficients and allowable loads for the flush-type shell connections.
Any idea where/how the stiffness coefficients and allowable loads for flush-type shell connections can be determined.
Thank you in advance for any reply/input.
DC
DC
RE: Stiffness and Allowable Loads for API 650 Flush-Type Shell Connection
Depending on the circumstances, it might be cheaper to rearrange the piping or add flexibility into the lines than to analyze the nozzles.
Thanks for your thought. The piping has some properly placed bends/elbows, based on experience, looks flexible.
The piping designer designated the flush-type shell connection as an ANC in Caesar. The analysis yielded a set of forces and moments at the ANC; and indicated the piping as meeting B31.3 code stress requirement.
I just wonder how the aforementioned set of piping reaction forces and moments at the ANC node could be qualified as acceptable for the flush-type shell connection. Would be most appreciative on any further thought on this.
Many thanks.
DC
I would only do FEA or other calc's if a pipe anchor or restraint was needed close to the tank. The 650 rules [actually] work.
Thanks for contributing. May I know where is "'pipe anchors' portion in API-653 inspx" stated? Just can't locate it in the latest API 653 I'm having (4th edtion, addendum 3, Nov. 2013).
