there are some anchor point on some drafting view, how to remove
my drawing view has some sketches on it,
and you can there is a blue anchor point on the tip and after the drawing is exported to PDF, the anchor point is exaggerated!!
what's the cause of it and how to remove it ?
thank you
http://files.engineering.com/getfile.aspx?folder=2...
thank you
RE: there are some anchor point on some drafting view, how to remove
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit
i draw the sketch in the model and set those sketch as reference set which is finally shown on the view.
that's all i did about the sketch in drafting view.
before exporting to PDf, i already notice those anchor point but very very small; however, after exporting, the anchor point became bigger...
Best regards,
Michaël.
Win 7 64 bit
when the expression changes, the sketch will also change and it will reflect on the drawing.
does manually drawin sketch link to models (associative)?
Best regards,
Michaël.
Win 7 64 bit
The "Anchor" is a point object in the sketch and can probably be deleted as such unless you need it for constraint purposes. If you need it for constraint purposes, place it on a hidden layer.
You can create associative sketches in drawings, you need to have Extracted edges in the Views to be able to snap / constrain to the geometry.
If so, the Sketch has Expressions.
What function did you use to create the Pdf ?
- The NX internal File-Export-Pdf or "some other pdf converter" ?
If "some other pdf converter", -ask the supplier of that converter why it does this, it's not an NX issue.
- Why not use the NX option ?
Tomas
looks like no anchor point appear at this time...........
so sad, my current has so many procedures so cannot figure out what step may contain "something" which make the drawing shows the anchor point.....
and dont know why the anchor pont bedomes bigger
yes, i am directly exporting to PDF using NX.
