Water table depth
Water table depth
What is the best way to find average water table depths of a site without a geotech report. USDA soils survey is what I used, but just wanted to know if there was a better source out there
RE: Water table depth
If a full blown geotechnical study isn't an option, send someone out with a hoe to dig some test pits. If water table is an issue for your design, then it's imperative you find out what that is first.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
As for using USDA soil maps, you might as well just guess.
Mike Lambert
It's important to get this right in Florida so you don't accidentally draw down a neighbor's water feature by setting your control elevation lower than the permanent pool on his property. Doing so could damage the value of his property and you'd be liable.
