Footings needed for tank pad?
I am designing a 14'x14' reinforced concrete pad to hold a 4000 gal water tank. I went through the design process for a one way slab and determined the slab thickness to be 12" thick with #6 bars at 12" spacing each way (top and bottom). Should I consider designing a grade beam at the edges or will a "floating" foundation be sufficient. My soil has a bearing capacity of 3,000 psf with a PI of 42. Any tips or considerations would be appreciated.
RE: Footings needed for tank pad?
Mike McCann
MMC Engineering
Using edge thickening to get below frost level doesn't help much as the middle portion will still be subject to frost heave.
BA
Dik
