Double Web Beam- AISC Specifications
Solving for the shear strength Vn of a beam with two webs, should the web thickness be doubled because of two webs when performing h/tw?
RE: Double Web Beam- AISC Specifications
O divide the shear load by 2. Is this an HSS tube section?
Mike McCann
MMC Engineering
No. The h/tw check is a buckling check, so you should use the thickness of one web.
When figuring the total shear area, you should use two web thicknesses.
