Seismic Force Distribution - Flexible Diaphragm
I have a question regarding seismic force distribution to vertical elements in which the the diaphragm is flexible and the plan is irregular. I have attached a sketch as to what I am referring to. My goal is to determine the forces in the three shear walls shown. I am concerned with the forces in the N-S direction.
I understand how to calculate the base shear and then distribute it vertically to the different levels. However, with a flexible diaphragm, the loads are distributed based on tributary area rather than the rigidity of the vertical elements. When calculating the force using the equations in ASCE 7-05 the units are not distributed (k rather than k/ft) therefore I can calculate the seismic force, but, in this example, it doesn't make sense to divide that load by LT because it would seem that the distributed load between the western edge of the building and the middle wall should be less than between the middle wall and the eastern edge.
In this case, would I calculate 2 different base shears? One would be along the length LA and the other along the length LB? I would then be able to transfer those loads across the respective tributary areas and have results that would seem a bit more accurate. If I simply took the force at the level and divided it by LT and applied it to the whole structure it would seem that the western wall would have an applied force that is higher than it should be and the eastern wall would have an applied force that is less than it should be.
Any thoughts or comments or references to literature that I could look into would be very helpful.
Thank you.
Thank you.
RE: Seismic Force Distribution - Flexible Diaphragm
Mike McCann
MMC Engineering
