Adding a new thread standard to nx502 file
I'm trying to add a new thread standard to the nx502_Threaded_Hole_Standard.xml file. After the new standard and data are added to the file and I reopen NX the hole command has error's and there are not any thread standard's available in the drop down menu.
RE: Adding a new thread standard to nx502 file
Can you upload your nx502_Threaded_Hole_Standard.xml file?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
The way that I modified it was to open the file in excel.
thanks for the help.
Steve
For example, I have over 3000 lines in my xml file and the size of the file is 2069KB. Your file has over 2400 lines, yet the file size is 4769KB. So, there are probably some data in your xml, that can not be recognized by NX.
I would advise the same as JohnRBaker already did. Try to edit this xml file in Wordpad or Notepad. I have copied and paste one line in Notepad, then change the standard and some parameters. And it worked.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks for the help.
Steve
