Creo-Hole Callout Not appearing
Hello all,
I'm currently having an issue with the annotation of holes. for instance I have a CS hole that is just a thru hole clearanced for a SHCS. But when I go to "Show Model Annotations" under the dimensions the diameters show up but when i go to the call out tab it doesn't show up.
It does work on another drawing for a threaded hole. is their a reason it doesn't work for thru holes? I don't need a custom .hol file I just need the standard diameter's and thru dimensions.
Thanks in advance!
Thanks in advance!
RE: Creo-Hole Callout Not appearing
The standard holes (non-tapped) do not have hole notes - they 'do not require them'.
