Floating Skimmer Device
Trying to model a floating skimmer device and not sure what flow to input in HydroCAD. Per the skimmer manual I will need two 6 inch skimmers w/H=0.417. The Basin volume needed to drain in 72 hours is 226,357 cuft. I have phase in depth set at 0.42 ft and Full flow set at 1.03 cfs.
RE: Floating Skimmer Device
Use the orifice equation to calculate the flow, based on the head and the skimmer geometry.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
I'm not sure what you're asking. If you've already determined the full flow to be 1.03 CFS, just enter that value into the constant-flow outlet device.
Peter Smart
HydroCAD Software
www.hydrocad.net
