Merge parts into one solid part
I need to merge 20 parts from assembley design to one solid part, so the model can be 3D printed.
I tried option "Generate part from product", but the files are still not connected into one inseparable part.
I've also tried to make 3dxml model and save it as STEP, but it doesen't work that way.
Did anyone ever had probloems with that and found the solution?
Regards, Dann
Regards, Dann
RE: Merge parts into one solid part
I think, that will be great solution!
At first I generated part from multiple parts, and then with boolean operation I merged all in one part.
