not include designated safe
Hello
When I want to save my work, the conflict manager returns me the following message:
The local primary site does not include designated safe for caching or active folder for this purpose.
Have you any idea?
RE: not include designated safe
What PLM system are you connected to?
In PDMLink (maybe Intralink, too) you need a cache content vault that has RW permissions to save and upload a file.
Ben Loosli
My system is Proe / Intralink
I just watched the rights to files, RW are OK. The novelty is that when you create a new work the problem does not appear. just on old pieces
Thank you for your help.
Check your Intralink vaults and be sure they are set to enabled for write from the File Manager. I am guessing you are on a version of Intralink that is Windchill based, 8 or higher?
Ben Loosli
This is Windchill 9.1
Thanks This is solved
