Simple Spring Damper Design
I am looking at designing a simple spring damper system for a small transporting wagon/trolley and I would like to calculate what spring and damper coefficients are needed to give the best ride (i.e. minimal disturbance of the load carried by the wagon). However I am struggling to find how the best way to approach this as I'm fairly new to spring damper systems.
The wagon will have a mass of approximately 20kg and will take a maximum load of 50kg. I was looking at two scenarios to optimism the suspension for:
1. a sudden drop or step of 5cm.
2. a continually undulating surface which I wanted to simulate as a Sin wave with an amplitude of 3cm and wavelength of 10cm.
I am expecting the maximum speed someone will pull the wagon will be 5kph. The wagon will have four wheels but there may also be a two wheel design and I'd like to simulate both options.
I realize this is probably a very simple problem, but I just can't figure out how to get started. I'll really appreciate any help.
Chris
Chris
RE: Simple Spring Damper Design
Cheers
Greg Locock
