SACS weight load error message, please help
I leaned this software by reading and go through old training material. Did two simple project went well.
But I get error on the weight and acceleration whe I applied weight under weight menu then use acceleration under environment. I don’t know why since I used same method before.
saclst Listing Error 17 *** SLV MODULE TERMINATED DUE TO ERRORS DETECTED IN THE PRE MODULE ***
saclst Listing Error 19 *** POST PROCESSOR TERMINATED DUE TO PREVIOUS ERRORS
saclst Listing Error 97 *** ERROR - LABEL INCW NOT RECOGNIZED AS PROPER
saclst Listing Error 99 *** ERROR - LABEL ACCE NOT RECOGNIZED AS PROPER
I changed weight on joint to make it simple and still get error message. Can anyone help me to find out why or where I did wrong?
Thanks first.
RE: SACS weight load error message, please help
hi,
i reviewed your file, in addition of what you mentioned, you didn't define sections, and not yet assigned,
Thanks c2l.
welcome
