Detail View from Break-out not updating (NX7.5.5.4)
I have an old drawing that had some recent changes and one of this changes was a component rotation (3D).
The drawing views was updated fine, but I noticed that a break-out section become out-of-position due to this component rotation, so I edited the break-out section and positioned it in correct place.
This break-out area of drawing was been called in a detail view, and here is the problem. This detail view probably is “converted as independent”. So, the internal lines are not updating with new condition of break-out section.
The view is up-to-date according NX. The clock icon does not appear in navigation panel. Even with this I forced the view update with right click menu "Update View" option.
This can be fixed or I will need to redraw the detail?
Attached is the drawing area with this issue to help the problem visualization (the same image that I put above).
Gerson Fioravanti Junior
Mechanical Production Engineer
RE: Detail View from Break-out not updating (NX7.5.5.4)
If you use "Extracted Edges" in your view, try turn these OFF + Update and ON + Update.
Right click the detail, - Style - General - Extracted edges = None + Apply
Extracted Edges = Associative + OK
Tomas
Thanks for your reply, Tomas.
Unfortunatelly, it was as NONE already. I tried to change settings to ASSOCIATIVE and it not worked too.
