VB code to export drawing file to PDF even through there are multiple drawing files are open
here is the original code by cowski: http://nxjournaling.com/?q=content/exporting-drawi...
i first played around the code but found that it worked only for the currently displayed part darwing. however, i have multiple part drawing open so i need to update those part drawing after the curently displayed part drawing is exported to PDF.
at first, i added the following
CODE --> vb
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Imports NXOpen.Annotations
Imports NXOpen.Utilities
Imports System.Text.RegularExpressions
Imports System.Collections.Generic
Imports System.IO
Imports System.Windows.Forms
Imports System.Windows.Forms.MessageBox
Imports NXOpen.Assemblies
Imports System.Environment
Imports System.Runtime.InteropServices
Module exprotPDF
    Dim theUI As UI = UI.GetUI()
    Dim theSession As Session = Session.GetSession()
    Dim theUfSession As UFSession = UFSession.GetUFSession()
    Dim LW As ListingWindow = theSession.ListingWindow
    Dim workPart As Part = theSession.Parts.Work
    Dim displayPart As Part = theSession.Parts.Display
    Sub Main()
        LW.Open()
        Dim i As Integer
        Dim pdfFile As String
        Dim currentPath As String
        Dim currentFile As String
        Dim exportFile As String
        Dim partUnits As Integer
        Dim strOutputFolder As String
        Dim strRevision As String
        Dim rspFileExists
        Dim rspAdvancePrint
        For Each tempPart As Part In theSession.Parts
            Dim partLoadStatus1 As PartLoadStatus
            Dim status1 As PartCollection.SdpsStatus
            status1 = theSession.Parts.SetDisplay(temppart, False, False, partLoadStatus1
            Dim dwgs As Drawings.DrawingSheetCollection
            dwgs = tempPart.DrawingSheets
            Dim sheet As Drawings.DrawingSheet
            currentPath = GetFilePath()
            currentFile = GetFileName()
            Try
                strRevision = tempPart.GetStringAttribute("REVISION")
                LW.WriteLine(strRevision)
                strRevision = Trim(strRevision)
            Catch ex As Exception
                strRevision = ""
            End Try
            exportFile = currentFile
            strOutputFolder = OutputPath()
            'if we don't have a valid directory (ie the user pressed 'cancel') exit the journal
            If Not Directory.Exists(strOutputFolder) Then
                Exit Sub
            End If
            strOutputFolder = strOutputFolder & "\"
            rspAdvancePrint = MessageBox.Show("Add advance print watermark?", "Add Watermark?", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
            Dim shts As New ArrayList()
            For Each sheet In dwgs
                shts.Add(sheet.Name)
            Next
            shts.Sort()
            i = 0
            Dim sht As String
            For Each sht In shts  '<-- the shts array
                    If sheet.Name = sht Then
                        i = i + 1
                        If rspAdvancePrint = vbYes Then
                            pdfFile = strOutputFolder & exportFile & "_advance" & ".pdf"
                        Else
                            If strRevision <> "" Then
                                pdfFile = strOutputFolder & exportFile & "_" & strRevision & ".pdf"
                            Else
                                pdfFile = strOutputFolder & exportFile & ".pdf"
                            End If
                        End If
                        'the pdf export uses 'append file', if we are on sheet 1 make sure the user wants to overwrite
                        'if the drawing is multisheet, don't ask on subsequent sheets
                        If i = 1 Then
                            If File.Exists(pdfFile) Then
                                rspFileExists = MsgBox("The file: '" & pdfFile & "' already exists; overwrite?", vbYesNo + vbQuestion)
                                If rspFileExists = vbYes Then
                                    Try
                                        File.Delete(pdfFile)
                                        MsgBox(ex.Message & vbCrLf & "Journal exiting", vbCritical + vbOKOnly, "Error")
                                        Exit Sub
                                    End Try
                                Else
                                    'msgbox("journal exiting", vbokonly)
                                    Exit Sub
                                End If
                            End If
                        End If
                        'update any views that are out of date
                        theSession.Parts.Work.DraftingViews.UpdateViews(Drawings.DraftingViewCollection.ViewUpdateOption.OutOfDate, sheet)
                        Try
                            ExportPDF(sheet, pdfFile, partUnits, rspAdvancePrint)
                            MsgBox("Error occurred in PDF export" & vbCrLf & ex.Message & vbCrLf & "journal exiting", vbCritical + vbOKOnly, "Error")
                            Exit Sub
                        End Try
                        Exit For
                    End If
                Next
            Next
            If i = 0 Then
                MessageBox.Show("This part has no drawing sheets to export", "PDF export failure", MessageBoxButtons.ok, MessageBoxIcon.Warning)
            Else
                MessageBox.Show("Exported: " & i & " sheet(s) to pdf file" & vbCrLf & pdfFile, "PDF export success", MessageBoxButtons.ok, MessageBoxIcon.Information)
            End If
        Next
    End Sub
    Function GetFileName()
        Dim strPath As String
        Dim strPart As String
        Dim pos As Integer
                'get the full file path
        strPath = displayPart.fullpath
        'get the part file name
        pos = InStrRev(strPath, "\")
        strPart = Mid(strPath, pos + 1)
        strPath = Left(strPath, pos)
        'strip off the ".prt" extension
        strPart = Left(strPart, Len(strPart) - 4)
        GetFileName = strPart
    End Function
    Function GetFilePath()
        Dim pos As Integer
        strPath = displayPart.FullPath
        GetFilePath = strPath
    End Function
    Function OutputPath()
        'Requires:
        '    Imports System.IO
        '    Imports System.Windows.Forms
        'if the user presses OK on the dialog box, the chosen path is returned
        'if the user presses cancel on the dialog box, 0 is returned
        Dim strLastPath As String
        Dim strOutputPath As String
        'Key will show up in HKEY_CURRENT_USER\Software\VB and VBA Program Settings
        Try
            'Get the last path used from the registry
            strLastPath = GetSetting("NX journal", "Export pdf", "ExportPath")
            'msgbox("Last Path: " & strLastPath)
        Catch e As ArgumentException
        Catch e As Exception
            MsgBox(e.GetType.ToString)
        Finally
        End Try
        Dim FolderBrowserDialog1 As New FolderBrowserDialog
        ' Then use the following code to create the Dialog window
        ' Change the .SelectedPath property to the default location
        With FolderBrowserDialog1
            ' Desktop is the root folder in the dialog.
            .RootFolder = Environment.SpecialFolder.Desktop
            ' Select the D:\home directory on entry.
            If Directory.Exists(strLastPath) Then
                .SelectedPath = strLastPath
            Else
                .SelectedPath = "D:\home"
            End If
            ' Prompt the user with a custom message.
            .Description = "Select the directory to export .pdf file"
            If .ShowDialog = DialogResult.OK Then
                ' Display the selected folder if the user clicked on the OK button.
                OutputPath = .SelectedPath
                ' save the output folder path in the registry for use on next run
                SaveSetting("NX journal", "Export pdf", "ExportPath", .SelectedPath)
            Else
                'user pressed 'cancel', exit the subroutine
                OutputPath = 0
                'exit sub
            End If
        End With
    End Function
    Sub ExportPDF(ByVal dwg As Drawings.DrawingSheet, ByVal outputFile As String, ByVal units As Integer, ByVal advancePrint As Integer)
        Dim printPDFBuilder1 As PrintPDFBuilder
                printPDFBuilder1 = workPart.PlotManager.CreatePrintPdfbuilder()
        printPDFBuilder1.Scale = 1.0
        printPDFBuilder1.Action = PrintPDFBuilder.ActionOption.Native
        printPDFBuilder1.Colors = PrintPDFBuilder.Color.BlackOnWhite
        printPDFBuilder1.Size = PrintPDFBuilder.SizeOption.ScaleFactor
        If units = 0 Then
            printPDFBuilder1.Units = PrintPDFBuilder.UnitsOption.English
        Else
            printPDFBuilder1.Units = PrintPDFBuilder.UnitsOption.Metric
        End If
        printPDFBuilder1.XDimension = dwg.height
        printPDFBuilder1.YDimension = dwg.length
        printPDFBuilder1.OutputText = PrintPDFBuilder.OutputTextOption.Polylines
        printPDFBuilder1.RasterImages = True
        printPDFBuilder1.ImageResolution = PrintPDFBuilder.ImageResolutionOption.Medium
        printPDFBuilder1.Append = True
        If advancePrint = vbyes Then
            printPDFBuilder1.AddWatermark = True
            printPDFBuilder1.Watermark = "ADVANCE PRINT NOT TO BE USED FOR PRODUCTION " & Today
        Else
            printPDFBuilder1.AddWatermark = False
            printPDFBuilder1.Watermark = ""
        End If
        Dim sheets1(0) As NXObject
        Dim drawingSheet1 As Drawings.DrawingSheet = CType(dwg, Drawings.DrawingSheet)
        sheets1(0) = drawingSheet1
        printPDFBuilder1.SourceBuilder.SetSheets(sheets1)
        printPDFBuilder1.Filename = outputFile
        Dim nXObject1 As NXObject
        nXObject1 = printPDFBuilder1.Commit()
        printPDFBuilder1.Destroy()
    End Sub
End Module
after the modification, i prepare two drawing part file called dwg1.prt and dwg2.prt
i run the code, the NX export dwg1.pdf, that's fine, and ready to switch to another part file
after switching to dwg2.prt, nx ask me that dwg1.pdf already exists, replace it?
then i asked myself why this happened? because at this stage, the displayed part is already dwg2.prt, so the file name should follow the currently displayed part drawing...
i kept modifiying and came up with the following solution marked in RED color:
CODE --> vb
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Imports System.IO
Module exprotPDF
    Sub Main()
        'Dim workPart As Part = theSession.Parts.Work     <---disabled by me originally outside of the Main
        'Dim displayPart As Part = theSession.Parts.Display  <---disabled by me originally outside of the Main
        LW.Open()
        Dim i As Integer
        Dim rspFileExists
        Dim rspAdvancePrint
            Try
                strRevision = ""
            End Try
                Exit Sub
            End If
            Next
            shts.Sort()
            i = 0
            Dim sht As String
                        i = i + 1
                        Else
                            Else
                            End If
                        End If
                        If i = 1 Then
                                    Try
                                        Exit Sub
                                    End Try
                                Else
                                    Exit Sub
                                End If
                            End If
                        End If
                        Try
                            Exit Sub
                        End Try
                        Exit For
                    End If
                Next
            Next
            If i = 0 Then
            Else
            End If
        Next
    End Sub
        Dim pos As Integer
        Dim displayPart As Part = theSession.Parts.Display   '<--added by me
    End Function
        Dim pos As Integer
    End Function
        'Requires:
        '    Imports System.IO
        Try
        Finally
        End Try
            Else
            End If
            Else
                OutputPath = 0
                'exit sub
            End If
        End With
    End Function
        Dim workPart As Part = theSession.Parts.Work   '<--added by me
        If units = 0 Then
        Else
        End If
        Else
        End If
    End Sub
End Module
RE: VB code to export drawing file to PDF even through there are multiple drawing files are open
this question kind of old for me but i always forgot to ask....
what 's the difference between declaring displaypart and workpart inside or outside the Sub Main()?
those added line were added because I guess that if displayPart and workPart are declared outside the Main(), it means they are global....
since i have multiple part files, i need to treat them individually, and that's why i deleted the declared workpart and displayed part outside the Main() and add them locally...
are my guess wrong AND any solution ?
thank you :)
Your assumptions are correct but it is better practice to only declare variables once. You could leave the declaration of the variables outside of the Sub Main() then set the variables again when you change to the next drawing. This can be done with displayPart = theSession.Parts.Display and workPart = theSession.Parts.Work, either in the functions where you placed them or just after changing drawing.
Mike Hyde
www.astonmartin.com
NX8.5 with TC9.1
If exporting a pdf is only a part of what your journal needs to do, I would suggest that you use the Pdf exporter class. Then all your code has to do is cycle through the parts in session and request a pdf export. Your resulting code might look something like:
CODE
'Output pdf of all parts in session.
Option Strict Off
Imports System
Imports System.IO
Imports NXOpen
Imports NXOpen.UF
Module Module2
    Sub Main()
        If IsNothing(theSession.Parts.Display) Then
            MessageBox.Show("Active Part Required", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
            Return
        End If
            status1 = theSession.Parts.SetDisplay(tempPart, False, False, partLoadStatus1)
            partLoadStatus1.Dispose()
            Dim myPdfExporter As New NXJ_PdfExporter
            myPdfExporter.Part = displayPart
            '$ show confirmation dialog box on completion
            myPdfExporter.ShowConfirmationDialog = True
            Try
                myPdfExporter.Commit()
                MessageBox.Show("Error:" & ControlChars.CrLf & ex.GetType.ToString & " : " & ex.Message, "PDF export error", MessageBoxButtons.OK, MessageBoxIcon.Error)
            Finally
                myPdfExporter = Nothing
            End Try
        Next
    End Sub
End Module
'copy and paste the pdf export class code here
'code not shown for brevity
www.nxjournaling.com
