SOL601 exit due to insufficient allocation of Memory
I have submitted a contact analysis using SOL601 from the Graphics window of NX CAE.And I got the following error and the run comes out. I have been pasting the corresponding log file. Please guide me.
NX Nastran V8.1 (Intel64 Family 6 Model 47 Stepping 2 Windows Server 2008 R2 Service Pack 1) Control File:
Nastran BUFFSIZE=8193 $(d:/program files/siemens/nx 8.0/nxnastran/conf/nast8.rcf[2])
Nastran DIAGA=128 DIAGB=0 $(d:/program files/siemens/nx 8.0/nxnastran/conf/nast8.rcf[6])
Nastran REAL=2147483647 $(program default)
JID='D:\NX Installations\Blade Shear failure analysis\Coarse mesh\asm0001_asm_igs_fem2_i_sim1-solution_2.dat'
OUT='./asm0001_asm_igs_fem2_i_sim1-solution_2'
MEM=2147483648
MACH='Intel64 Family 6 Model 47 Stepping 2'
OPER='Windows Server 2008 R2'
OSV='Service Pack 1'
MODEL='Intel(R) Xeon(R) CPU E7- 4830 @ 2.13GHz (INBAOMNASTSRV)'
CONFIG=8666
NPROC=32
symbol=DELDIR='d:/program files/siemens/nx 8.0/nxnastran/nxn8p1/nast/del' $(program default)
symbol=DEMODIR='d:/program files/siemens/nx 8.0/nxnastran/nxn8p1/nast/demo' $(program default)
symbol=SSSALTERDIR='d:/program files/siemens/nx 8.0/nxnastran/nxn8p1/nast/misc/sssalter' $(program default)
symbol=TPLDIR='d:/program files/siemens/nx 8.0/nxnastran/nxn8p1/nast/tpl' $(program default)
SDIR='d:/nx installations/blade shear failure analysis/coarse mesh/asm0001_asm_igs_fem2_i_sim1-solution_2.T732_39'
DBS='d:/nx installations/blade shear failure analysis/coarse mesh/asm0001_asm_igs_fem2_i_sim1-solution_2.T732_39'
SCR=yes
NEWDEL='d:/program files/siemens/nx 8.0/nxnastran/nxn8p1/em64tnt/SSS'
DEL='NXNDEF'
AUTH='28000@inbaomnastsrv'
AUTHQUE=0
MSGCAT='d:/program files/siemens/nx 8.0/nxnastran/nxn8p1/em64tnt/analysis.msg'
MSGDEST='f06'
NEWS='d:/program files/siemens/nx 8.0/nxnastran/nxn8p1/nast/news.txt'
NXN_ISHELLPATH=D:\Program Files\Siemens\NX 8.0\NXNASTRAN\bin
NXN_JIDPATH=
PATH=d:/program files/siemens/nx 8.0/nxnastran/nxn8p1/em64tnt;d:/program files/siemens/nx 8.0/nxnastran/nxn8p1/em64tnt/mpi/bin;D:\Program Files\Siemens\NX 8.0\ugii;C:\Program Files\Microsoft HPC Pack 2008 R2\Bin\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;D:\SIMULIA\Abaqus\Commands
Command Line: asm0001_asm_igs_fem2_i_sim1-solution_2.dat old=no memory=8gb scratch=yes sdirectory=D:\NX Installations\Blade Shear failure analysis\Coarse mesh
Current Dir: D:\NX Installations\Blade Shear failure analysis\Coarse mesh
Executable: d:/program files/siemens/nx 8.0/nxnastran/nxn8p1/em64tnt/analysis.exe
NXN_MSG: stderr
FPE: no
Current resource limits:
Physical memory: 98223 MB
Physical memory available: 89782 MB
Paging file size: 196445 MB
Paging file size available: 188710 MB
Virtual memory: 8388607 MB
Virtual memory available: 8388553 MB
System configuration:
Hostname: INBAOMNASTSRV.in002.siemens.net
Architecture: em64tnt
Platform: Intel64 Family 6 Model 47 Stepping 2 Windows Server 2008 R2 Service Pack 1
Model: Intel(R) Xeon(R) CPU E7- 4830 @ 2.13GHz
Clock freq.: 2128 MHz
Number of CPUs: 32
Executable: standard
Raw model ID: 8666
Config number: 8666
Virtual memory: 196445 MB
Numeric format: 32-bit little-endian IEEE.
Bytes per word: 4
Disk block size: 512 bytes (128 words)
Remote shell cmd: "d:/program files/siemens/nx 8.0/nxnastran/nxn8p1/em64tnt/edsrmtcmd.exe" (Windows, UNIX)
NX Nastran started Mon Jun 23 19:21:39 IST 2014
*** MEMORY REQUEST EXCEEDS LP-64 LIMIT OF 2047 MW ***
OPEN CORE Allocation Failed
Real: 0.031 seconds ( 0:00:00.031)
User: 0.000 seconds ( 0:00:00.000)
Sys: 0.031 seconds ( 0:00:00.031)
NX Nastran finished Mon Jun 23 19:21:39 IST 2014
RE: SOL601 exit due to insufficient allocation of Memory
Hello!,
You are running the LP-64 solver of NX NASTRAN that is limited to 8 GB, and you use the nastran keyboard MEM=8GB, then the error. Either use the ILP-64 solver with bytes per word = 8, or better reduce the memory assigned to the solver using say MEM=5GB
The amount of memory needed by the solver is output in the *.F04 file. Important values are: (a) minimum memory required, (b) memory required to avoid spill, and (c) memory available. An excerpt is shown below:
Best regards,
Blas.
PD
To learn more about the NX NASTRAN Hardware Requirements take a look to my block in the following address:
http://iberisa.wordpress.com/2014/01/03/requisitos...
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48004 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
