sequantial numbering
Hi all,
I have table which consist of 12 columns and over 65000 rows. Except the first three columns, all date are numerical. The unwanted value in the data are blanks, 0 and 1, although I don't want to delete them.
At the moment all data are organised in ascending order based on the format of (dd/mm/yyyy hh:mm:ss). Without the unwanted values, I want to create a new column number each row sequentially by whole numbers instead of dates. As a result, I am hoping to plot a graph using the new column as the x-axis
Mnay Thanks
Felix
RE: sequantial numbering
Hi IRstuff,
Thanks for the response.
if there is no blanks or any unwanted values, your method will work.
However, I have some unwanted values that I want to take out.
Hence below
a b c d e f g h i j k
15/01/2014 03:01 15-Jan-2014 03:01:01 Wed 13 12 8 14 12 8 9 58
15/01/2014 03:02 15-Jan-2014 03:02:01 Wed 14 12 8 13 11 8 9 57
15/01/2014 03:03 15-Jan-2014 03:03:01 Wed 14 13 8 14 11 8 9 56
15/01/2014 03:04 15-Jan-2014 03:04:01 Wed 14 12 8 14 11 9 9 54
15/01/2014 03:05 15-Jan-2014 03:05:01 Wed 14 13 8 13 12 8 9 53
15/01/2014 03:06 15-Jan-2014 03:06:01 Wed 14 13 9 15 12 8 8 52
15/01/2014 03:07 15-Jan-2014 03:07:01 Wed 14 13 8 14 12 8 8 51
15/01/2014 03:08 15-Jan-2014 03:08:01 Wed 14 13 8 14 12 8 9 50
15/01/2014 03:09 15-Jan-2014 03:09:01 Wed 14 13 8 15 12 8 9 50
15/01/2014 03:10 15-Jan-2014 03:10:01 Wed 14 13 9 9 49
15/01/2014 03:11 15-Jan-2014 03:11:01 Wed 14 13 8 14 12 9 9 49
15/01/2014 03:12 15-Jan-2014 03:12:01 Wed 14 13 8 14 12 8 9 48
15/01/2014 03:13 15-Jan-2014 03:13:01 Wed 14 13 8 9 47
15/01/2014 03:14 15-Jan-2014 03:14:01 Wed 14 13 8 9 45
15/01/2014 03:15 15-Jan-2014 03:15:01 Wed 14 13 8 9 44
15/01/2014 03:16 15-Jan-2014 03:16:01 Wed 14 12 8 13 11 8 9 42
15/01/2014 03:17 15-Jan-2014 03:17:01 Wed 14 12 8 0 0 0 9 42
15/01/2014 03:18 15-Jan-2014 03:18:01 Wed 14 13 8 0 0 0 9 41
15/01/2014 03:19 15-Jan-2014 03:19:01 Wed 14 13 8 14 12 8 9 41
15/01/2014 03:20 15-Jan-2014 03:20:01 Wed 18 17 9 18 16 10 10 44
15/01/2014 03:21 15-Jan-2014 03:21:01 Wed 17 16 8 17 15 9 10 48
15/01/2014 03:22 15-Jan-2014 03:22:01 Wed 17 15 8 17 15 8 11 49
15/01/2014 03:23 15-Jan-2014 03:23:01 Wed 18 15 8 16 14 8 10 52
15/01/2014 03:24 15-Jan-2014 03:24:01 Wed 19 15 8 16 14 8 11 53
15/01/2014 03:25 15-Jan-2014 03:25:01 Wed 17 14 8 16 13 8 12 53
15/01/2014 03:26 15-Jan-2014 03:26:01 Wed 16 14 8 15 13 8 11 55
15/01/2014 03:27 15-Jan-2014 03:27:01 Wed 20 14 8 15 11 8 12 56
15/01/2014 03:28 15-Jan-2014 03:28:01 Wed 22 14 8 14 11 8 12 57
15/01/2014 03:29 15-Jan-2014 03:29:01 Wed 23 15 8 14 11 8 11 58
15/01/2014 03:30 15-Jan-2014 03:30:01 Wed 23 15 8 14 11 8 11 59
15/01/2014 03:31 15-Jan-2014 03:31:01 Wed 23 15 8 14 11 8 11 60
15/01/2014 03:32 15-Jan-2014 03:32:01 Wed 22 13 8 14 11 8 11 62
15/01/2014 03:33 15-Jan-2014 03:33:01 Wed 20 16 13 15 14 10 10 66
15/01/2014 03:34 15-Jan-2014 03:34:01 Wed 19 14 12 14 13 9 10 65
15/01/2014 03:35 15-Jan-2014 03:35:01 Wed 17 16 13 16 14 9 10 66
15/01/2014 03:36 15-Jan-2014 03:36:01 Wed 16 15 12 16 13 8 9 64
15/01/2014 03:37 15-Jan-2014 03:37:01 Wed 16 14 9 14 12 8 9 63
15/01/2014 03:38 15-Jan-2014 03:38:01 Wed 15 14 10 15 13 8 9 65
15/01/2014 03:39 15-Jan-2014 03:39:01 Wed 16 14 9 14 12 8 9 62
15/01/2014 03:40 15-Jan-2014 03:40:01 Wed 15 14 9 17 12 8 9 64
15/01/2014 03:41 15-Jan-2014 03:41:01 Wed 15 13 8 17 12 8 9 62
15/01/2014 03:42 15-Jan-2014 03:42:01 Wed 14 13 8 15 12 8 9 63
15/01/2014 03:43 15-Jan-2014 03:43:01 Wed 14 13 8 18 12 8 9 64
15/01/2014 03:44 15-Jan-2014 03:44:01 Wed 14 12 8 14 11 8 9 62
15/01/2014 03:45 15-Jan-2014 03:45:01 Wed 14 12 8 14 11 8 10 62
15/01/2014 03:46 15-Jan-2014 03:46:01 Wed 14 12 8 17 12 8 9 65
15/01/2014 03:47 15-Jan-2014 03:47:01 Wed 14 12 8 17 11 8 9 65
15/01/2014 03:48 15-Jan-2014 03:48:01 Wed 14 12 8 17 12 8 9 63
15/01/2014 03:49 15-Jan-2014 03:49:01 Wed 14 12 8 16 11 8 9 63
15/01/2014 03:50 15-Jan-2014 03:50:01 Wed 14 12 8 16 11 8 9 64
15/01/2014 03:51 15-Jan-2014 03:51:01 Wed 14 12 8 0 0 0 9 64
15/01/2014 03:52 15-Jan-2014 03:52:01 Wed 13 12 8 0 0 0 9 63
15/01/2014 03:53 15-Jan-2014 03:53:01 Wed 13 11 8 0 0 0 9 64
15/01/2014 03:54 15-Jan-2014 03:54:01 Wed 13 11 8 0 0 0 9 63
15/01/2014 03:55 15-Jan-2014 03:55:01 Wed 13 12 8 0 0 0 9 63
15/01/2014 03:56 15-Jan-2014 03:56:01 Wed 13 11 8 0 0 0 9 63
15/01/2014 03:57 15-Jan-2014 03:57:01 Wed 14 12 8 0 0 0 9 64
15/01/2014 03:58 15-Jan-2014 03:58:01 Wed 13 12 8 17 10 8 9 64
15/01/2014 03:59 15-Jan-2014 03:59:01 Wed 13 12 8 18 11 8 9 64
15/01/2014 04:00 15-Jan-2014 04:00:01 Wed 13 12 8 13 11 8 9 64
15/01/2014 04:01 15-Jan-2014 04:01:01 Wed 13 11 8 16 11 8 9 67
15/01/2014 04:02 15-Jan-2014 04:02:01 Wed 13 11 8 16 11 8 9 65
15/01/2014 04:03 15-Jan-2014 04:03:01 Wed 13 11 8 13 11 8 9 64
15/01/2014 04:04 15-Jan-2014 04:04:01 Wed 13 11 8 14 10 8 9 65
15/01/2014 04:05 15-Jan-2014 04:05:01 Wed 13 11 8 14 10 8 9 62
15/01/2014 04:06 15-Jan-2014 04:06:01 Wed 13 11 8 12 9 8 10 59
15/01/2014 04:07 15-Jan-2014 04:07:01 Wed 12 11 8 14 9 8 10 60
15/01/2014 04:08 15-Jan-2014 04:08:01 Wed 12 11 8 12 10 8 10 59
15/01/2014 04:09 15-Jan-2014 04:09:01 Wed 13 11 8 11 9 8 10 59
15/01/2014 04:10 15-Jan-2014 04:10:01 Wed 12 11 8 12 9 8 10 58
15/01/2014 04:11 15-Jan-2014 04:11:01 Wed 12 10 8 12 11 8 10 59
15/01/2014 04:12 15-Jan-2014 04:12:01 Wed 12 10 8 12 10 8 10 58
15/01/2014 04:13 15-Jan-2014 04:13:01 Wed 12 10 8 12 9 8 9 59
15/01/2014 04:14 15-Jan-2014 04:14:01 Wed 12 9 8 12 9 8 9 61
15/01/2014 04:15 15-Jan-2014 04:15:01 Wed 12 10 8 12 9 8 10 60
15/01/2014 04:16 15-Jan-2014 04:16:01 Wed 12 9 8 12 10 8 10 60
15/01/2014 04:17 15-Jan-2014 04:17:01 Wed 12 10 8 11 10 8 10 61
15/01/2014 04:18 15-Jan-2014 04:18:01 Wed 12 10 8 13 10 8 10 60
15/01/2014 04:19 15-Jan-2014 04:19:01 Wed 12 10 8 17 10 8 10 60
15/01/2014 04:20 15-Jan-2014 04:20:01 Wed 12 9 8 12 10 8 10 58
15/01/2014 04:21 15-Jan-2014 04:21:01 Wed 11 9 8 17 10 8 10 61
15/01/2014 04:22 15-Jan-2014 04:22:01 Wed 11 9 8 12 10 8 10 58
15/01/2014 04:23 15-Jan-2014 04:23:01 Wed 12 10 8 10 9 8 10 61
15/01/2014 04:24 15-Jan-2014 04:24:01 Wed 11 9 8 11 9 8 10 60
15/01/2014 04:25 15-Jan-2014 04:25:01 Wed 11 10 8 13 9 8 10 61
15/01/2014 04:26 15-Jan-2014 04:26:01 Wed 11 9 8 11 9 8 10 59
15/01/2014 04:27 15-Jan-2014 04:27:01 Wed 11 9 8 1 1 1 10 58
15/01/2014 04:28 15-Jan-2014 04:28:01 Wed 11 10 8 12 10 8 10 59
15/01/2014 04:29 15-Jan-2014 04:29:01 Wed 11 10 8 11 9 8 10 61
15/01/2014 04:30 15-Jan-2014 04:30:01 Wed 11 9 8 11 10 8 10 61
15/01/2014 04:31 15-Jan-2014 04:31:01 Wed 11 10 8 15 9 8 9 64
15/01/2014 04:32 15-Jan-2014 04:32:01 Wed 12 11 8 18 10 8 9 65
15/01/2014 04:33 15-Jan-2014 04:33:01 Wed 12 11 8 18 9 8 9 65
15/01/2014 04:34 15-Jan-2014 04:34:01 Wed 12 10 8 19 11 8 9 65
15/01/2014 04:35 15-Jan-2014 04:35:01 Wed 12 11 8 14 9 8 9 65
15/01/2014 04:36 15-Jan-2014 04:36:01 Wed 13 11 8 17 11 8 9 65
15/01/2014 04:37 15-Jan-2014 04:37:01 Wed 13 12 8 13 11 8 9 65
15/01/2014 04:38 15-Jan-2014 04:38:01 Wed 13 11 8 13 11 8 9 64
15/01/2014 04:39 15-Jan-2014 04:39:01 Wed 13 12 8 17 11 8 9 64
15/01/2014 04:40 15-Jan-2014 04:40:01 Wed 13 12 8 13 12 8 9 64
15/01/2014 04:41 15-Jan-2014 04:41:01 Wed 13 11 8 15 11 8 9 64
15/01/2014 04:42 15-Jan-2014 04:42:01 Wed 13 12 8 13 11 8 9 65
15/01/2014 04:43 15-Jan-2014 04:43:01 Wed 14 12 8 13 11 8 10 63
15/01/2014 04:44 15-Jan-2014 04:44:01 Wed 14 12 8 16 12 8 9 66
15/01/2014 04:45 15-Jan-2014 04:45:01 Wed 14 12 8 13 12 8 9 66
15/01/2014 04:46 15-Jan-2014 04:46:01 Wed 13 12 8 13 11 8 9 66
15/01/2014 04:47 15-Jan-2014 04:47:01 Wed 13 12 8 13 11 8 9 67
15/01/2014 04:48 15-Jan-2014 04:48:01 Wed 13 12 8 13 11 8 9 67
15/01/2014 04:49 15-Jan-2014 04:49:01 Wed 13 11 8 13 11 8 9 68
15/01/2014 04:50 15-Jan-2014 04:50:01 Wed 13 11 8 12 10 8 9 70
15/01/2014 04:51 15-Jan-2014 04:51:01 Wed 12 11 8 12 10 8 9 69
15/01/2014 04:52 15-Jan-2014 04:52:01 Wed 13 11 8 12 10 8 9 69
15/01/2014 04:53 15-Jan-2014 04:53:01 Wed 13 11 8 14 10 8 9 68
15/01/2014 04:54 15-Jan-2014 04:54:01 Wed 13 11 8 12 11 8 9 68
15/01/2014 04:55 15-Jan-2014 04:55:01 Wed 13 11 8 13 11 8 9 70
15/01/2014 05:19 15-Jan-2014 05:19:06 Wed 13 52
15/01/2014 05:20 15-Jan-2014 05:20:06 Wed 15 14 10 15 14 11 14 50
15/01/2014 05:21 15-Jan-2014 05:21:06 Wed 15 14 10 15 13 10 13 50
15/01/2014 05:22 15-Jan-2014 05:22:06 Wed 15 14 8 15 13 8 12 50
15/01/2014 05:23 15-Jan-2014 05:23:06 Wed 15 14 8 15 13 8 12 49
15/01/2014 05:24 15-Jan-2014 05:24:06 Wed 15 14 8 15 13 9 12 48
15/01/2014 05:25 15-Jan-2014 05:25:06 Wed 15 14 8 15 13 8 11 47
15/01/2014 05:26 15-Jan-2014 05:26:06 Wed 15 14 9 15 12 9 11 47
15/01/2014 05:27 15-Jan-2014 05:27:06 Wed 15 13 8 15 13 8 11 46
15/01/2014 05:28 15-Jan-2014 05:28:06 Wed 15 13 8 14 12 8 10 46
15/01/2014 05:29 15-Jan-2014 05:29:06 Wed 18 16 9 18 16 10 11 48
15/01/2014 05:30 15-Jan-2014 05:30:06 Wed 17 16 9 18 15 8 12 46
15/01/2014 05:31 15-Jan-2014 05:31:06 Wed 17 15 8 17 15 8 12 46
15/01/2014 05:32 15-Jan-2014 05:32:06 Wed 17 15 9 18 15 8 12 46
15/01/2014 05:33 15-Jan-2014 05:33:06 Wed 17 15 8 17 15 8 12 45
15/01/2014 05:34 15-Jan-2014 05:34:06 Wed 17 15 8 17 15 8 12 45
15/01/2014 05:35 15-Jan-2014 05:35:06 Wed 17 15 8 17 14 8 12 44
15/01/2014 05:36 15-Jan-2014 05:36:06 Wed 17 15 8 17 14 8 12 44
15/01/2014 05:37 15-Jan-2014 05:37:06 Wed 17 15 8 17 14 8 12 43
15/01/2014 05:38 15-Jan-2014 05:38:06 Wed 17 15 8 12 43
15/01/2014 05:39 15-Jan-2014 05:39:06 Wed 17 15 8 17 14 8 12 42
15/01/2014 05:40 15-Jan-2014 05:40:06 Wed 16 15 8 12 42
15/01/2014 05:41 15-Jan-2014 05:41:06 Wed 16 14 8 16 14 8 12 41
15/01/2014 05:42 15-Jan-2014 05:42:06 Wed 16 14 8 17 14 8 12 41
15/01/2014 05:43 15-Jan-2014 05:43:06 Wed 16 15 8 12 41
15/01/2014 05:44 15-Jan-2014 05:44:06 Wed 16 14 8 12 41
15/01/2014 05:45 15-Jan-2014 05:45:06 Wed 18 16 9 16 14 9 11 43
15/01/2014 05:46 15-Jan-2014 05:46:06 Wed 18 16 9 18 16 9 11 46
15/01/2014 05:47 15-Jan-2014 05:47:06 Wed 18 16 8 17 15 8 11 47
15/01/2014 05:48 15-Jan-2014 05:48:06 Wed 18 15 8 17 14 8 10 55
15/01/2014 05:49 15-Jan-2014 05:49:06 Wed 17 15 8 16 14 8 11 53
15/01/2014 05:50 15-Jan-2014 05:50:06 Wed 17 14 8 16 14 8 12 52
15/01/2014 05:51 15-Jan-2014 05:51:06 Wed 20 14 8 15 13 8 12 53
15/01/2014 05:52 15-Jan-2014 05:52:06 Wed 21 15 8 15 12 8 12 55
15/01/2014 05:53 15-Jan-2014 05:53:06 Wed 23 15 8 15 12 8 12 55
15/01/2014 05:54 15-Jan-2014 05:54:06 Wed 20 13 8 15 12 8 13 55
15/01/2014 05:55 15-Jan-2014 05:55:06 Wed 17 12 8 14 11 8 12 54
15/01/2014 05:56 15-Jan-2014 05:56:06 Wed 14 11 8 14 11 8 12 54
15/01/2014 05:57 15-Jan-2014 05:57:06 Wed 14 12 8 14 11 8 12 53
15/01/2014 05:58 15-Jan-2014 05:58:06 Wed 13 11 8 14 11 8 12 53
15/01/2014 05:59 15-Jan-2014 05:59:06 Wed 13 11 8 13 10 8 12 52
15/01/2014 06:00 15-Jan-2014 06:00:06 Wed 13 11 8 13 11 8 12 55
15/01/2014 06:01 15-Jan-2014 06:01:06 Wed 13 11 8 13 10 8 11 55
15/01/2014 06:02 15-Jan-2014 06:02:06 Wed 13 11 8 13 10 8 11 54
15/01/2014 06:03 15-Jan-2014 06:03:06 Wed 13 11 8 13 11 8 10 56
15/01/2014 06:04 15-Jan-2014 06:04:06 Wed 16 14 8 15 13 8 10 55
15/01/2014 06:05 15-Jan-2014 06:05:06 Wed 15 14 8 15 13 9 10 54
15/01/2014 06:06 15-Jan-2014 06:06:06 Wed 15 13 8 15 13 8 10 55
15/01/2014 06:07 15-Jan-2014 06:07:06 Wed 15 13 8 16 13 8 10 56
15/01/2014 06:08 15-Jan-2014 06:08:06 Wed 15 13 8 16 13 8 10 56
15/01/2014 06:09 15-Jan-2014 06:09:06 Wed 15 13 8 17 13 8 10 57
15/01/2014 06:10 15-Jan-2014 06:10:06 Wed 15 13 8 14 12 8 10 58
15/01/2014 06:11 15-Jan-2014 06:11:06 Wed 14 13 8 17 12 8 10 59
15/01/2014 06:12 15-Jan-2014 06:12:06 Wed 15 13 8 14 12 8 10 57
15/01/2014 06:13 15-Jan-2014 06:13:06 Wed 14 13 8 16 12 8 10 58
15/01/2014 06:14 15-Jan-2014 06:14:06 Wed 14 13 8 16 12 8 9 60
15/01/2014 06:15 15-Jan-2014 06:15:06 Wed 14 13 8 15 13 8 10 58
15/01/2014 06:16 15-Jan-2014 06:16:06 Wed 14 12 8 15 12 8 11 55
15/01/2014 06:17 15-Jan-2014 06:17:06 Wed 14 12 8 14 11 9 11 53
15/01/2014 06:18 15-Jan-2014 06:18:06 Wed 14 11 8 14 11 8 11 52
15/01/2014 06:19 15-Jan-2014 06:19:06 Wed 13 11 8 13 11 8 10 52
15/01/2014 06:20 15-Jan-2014 06:20:06 Wed 13 12 8 15 11 8 11 51
15/01/2014 06:21 15-Jan-2014 06:21:06 Wed 13 12 8 14 12 8 11 50
15/01/2014 06:22 15-Jan-2014 06:22:06 Wed 14 13 9 14 12 8 10 52
15/01/2014 06:23 15-Jan-2014 06:23:06 Wed 14 12 8 14 12 8 11 49
15/01/2014 06:24 15-Jan-2014 06:24:06 Wed 13 11 8 14 12 9 11 49
15/01/2014 06:25 15-Jan-2014 06:25:06 Wed 14 12 8 15 11 8 10 53
15/01/2014 06:26 15-Jan-2014 06:26:06 Wed 14 13 8 14 12 8 10 53
15/01/2014 06:27 15-Jan-2014 06:27:06 Wed 14 13 8 14 12 8 10 55
15/01/2014 06:28 15-Jan-2014 06:28:06 Wed 15 13 8 14 13 8 10 58
15/01/2014 06:29 15-Jan-2014 06:29:06 Wed 15 13 8 16 12 8 10 57
15/01/2014 06:30 15-Jan-2014 06:30:06 Wed 15 13 9 14 12 8 10 58
15/01/2014 06:31 15-Jan-2014 06:31:06 Wed 14 12 8 14 12 8 10 57
15/01/2014 06:32 15-Jan-2014 06:32:06 Wed 13 11 8 14 12 8 10 55
15/01/2014 06:33 15-Jan-2014 06:33:06 Wed 14 12 8 13 11 8 10 56
15/01/2014 06:34 15-Jan-2014 06:34:06 Wed 13 12 8 13 11 8 10 55
15/01/2014 06:35 15-Jan-2014 06:35:06 Wed 14 12 8 13 11 8 10 55
15/01/2014 06:36 15-Jan-2014 06:36:06 Wed 13 11 8 13 11 8 10 56
15/01/2014 06:37 15-Jan-2014 06:37:06 Wed 13 11 8 13 11 8 10 54
15/01/2014 06:38 15-Jan-2014 06:38:06 Wed 13 11 8 12 11 8 10 55
15/01/2014 06:39 15-Jan-2014 06:39:06 Wed 12 11 8 12 10 8 10 55
15/01/2014 06:40 15-Jan-2014 06:40:06 Wed 13 11 8 12 10 8 10 54
15/01/2014 06:41 15-Jan-2014 06:41:06 Wed 13 11 8 12 10 8 10 54
15/01/2014 06:42 15-Jan-2014 06:42:06 Wed 12 10 8 12 11 8 10 57
15/01/2014 06:43 15-Jan-2014 06:43:06 Wed 13 11 8 13 10 8 10 54
15/01/2014 06:44 15-Jan-2014 06:44:06 Wed 13 12 8 15 11 8 10 60
15/01/2014 06:45 15-Jan-2014 06:45:06 Wed 14 12 8 13 11 8 10 60
15/01/2014 07:27 15-Jan-2014 07:27:48 Wed 9 19
15/01/2014 07:28 15-Jan-2014 07:28:48 Wed 17 16 11 17 16 13 17 37
15/01/2014 07:29 15-Jan-2014 07:29:48 Wed 18 16 10 18 16 8 13 46
15/01/2014 07:30 15-Jan-2014 07:30:48 Wed 18 16 8 18 15 9 11 53
15/01/2014 07:31 15-Jan-2014 07:31:48 Wed 17 15 8 17 14 8 12 45
15/01/2014 07:32 15-Jan-2014 07:32:48 Wed 20 18 9 18 16 8 11 50
15/01/2014 07:33 15-Jan-2014 07:33:48 Wed 20 17 8 18 15 9 12 52
15/01/2014 07:34 15-Jan-2014 07:34:48 Wed 18 16 8 17 14 8 12 53
15/01/2014 07:35 15-Jan-2014 07:35:48 Wed 18 15 8 16 14 8 11 57
15/01/2014 07:36 15-Jan-2014 07:36:48 Wed 23 16 8 18 13 8 11 58
15/01/2014 07:37 15-Jan-2014 07:37:48 Wed 22 15 8 16 13 8 10 65
15/01/2014 07:38 15-Jan-2014 07:38:48 Wed 22 16 8 19 13 8 9 66
15/01/2014 07:39 15-Jan-2014 07:39:48 Wed 23 17 9 19 14 9 9 66
15/01/2014 07:40 15-Jan-2014 07:40:48 Wed 18 15 10 18 14 9 9 66
15/01/2014 07:41 15-Jan-2014 07:41:48 Wed 19 15 8 18 14 9 9 66
15/01/2014 07:42 15-Jan-2014 07:42:48 Wed 17 15 8 18 14 8 9 66
15/01/2014 07:43 15-Jan-2014 07:43:48 Wed 17 15 8 18 13 8 8 67
15/01/2014 07:44 15-Jan-2014 07:44:48 Wed 17 14 8 17 13 8 8 69
15/01/2014 07:45 15-Jan-2014 07:45:48 Wed 16 14 8 18 14 8 8 67
15/01/2014 07:46 15-Jan-2014 07:46:48 Wed 17 14 8 20 16 12 8 70
15/01/2014 07:47 15-Jan-2014 07:47:48 Wed 16 14 8 19 14 9 8 71
15/01/2014 07:48 15-Jan-2014 07:48:48 Wed 16 14 8 17 13 8 8 70
15/01/2014 07:49 15-Jan-2014 07:49:48 Wed 16 13 8 17 13 8 8 69
15/01/2014 07:50 15-Jan-2014 07:50:48 Wed 15 13 8 16 12 8 8 70
15/01/2014 07:51 15-Jan-2014 07:51:48 Wed 15 13 8 16 12 8 8 70
15/01/2014 07:52 15-Jan-2014 07:52:48 Wed 15 13 8 16 12 8 8 70
15/01/2014 07:53 15-Jan-2014 07:53:48 Wed 15 13 8 17 12 8 8 71
15/01/2014 07:54 15-Jan-2014 07:54:48 Wed 15 13 8 17 11 8 8 71
15/01/2014 07:55 15-Jan-2014 07:55:48 Wed 14 12 8 18 12 8 8 70
15/01/2014 07:56 15-Jan-2014 07:56:48 Wed 14 12 8 16 12 8 8 72
15/01/2014 07:57 15-Jan-2014 07:57:48 Wed 14 13 8 14 11 9 9 67
15/01/2014 07:58 15-Jan-2014 07:58:48 Wed 18 16 9 19 16 9 8 72
15/01/2014 07:59 15-Jan-2014 07:59:48 Wed 17 16 9 18 15 9 8 72
15/01/2014 08:00 15-Jan-2014 08:00:48 Wed 17 15 8 17 15 8 8 71
15/01/2014 08:01 15-Jan-2014 08:01:48 Wed 17 15 8 17 15 8 8 71
15/01/2014 08:02 15-Jan-2014 08:02:48 Wed 16 15 9 16 14 8 8 70
15/01/2014 08:03 15-Jan-2014 08:03:48 Wed 16 15 9 17 14 8 8 71
15/01/2014 08:04 15-Jan-2014 08:04:48 Wed 16 14 9 19 15 8 8 73
15/01/2014 08:05 15-Jan-2014 08:05:48 Wed 16 14 8 17 14 8 8 73
15/01/2014 08:06 15-Jan-2014 08:06:48 Wed 16 14 9 17 14 8 8 74
15/01/2014 08:07 15-Jan-2014 08:07:48 Wed 16 14 9 19 15 8 8 75
15/01/2014 08:08 15-Jan-2014 08:08:48 Wed 15 14 8 15 13 8 9 69
15/01/2014 08:09 15-Jan-2014 08:09:48 Wed 18 16 9 18 16 9 8 72
15/01/2014 08:10 15-Jan-2014 08:10:48 Wed 17 16 8 18 15 8 8 72
15/01/2014 08:11 15-Jan-2014 08:11:48 Wed 17 15 8 17 14 8 8 72
15/01/2014 08:12 15-Jan-2014 08:12:48 Wed 17 15 8 17 15 9 8 72
15/01/2014 08:13 15-Jan-2014 08:13:48 Wed 17 15 8 17 14 9 8 73
15/01/2014 08:14 15-Jan-2014 08:14:48 Wed 16 15 9 18 15 10 8 74
15/01/2014 08:15 15-Jan-2014 08:15:48 Wed 16 15 9 19 14 8 8 74
15/01/2014 08:16 15-Jan-2014 08:16:48 Wed 16 14 8 18 14 8 8 74
15/01/2014 08:17 15-Jan-2014 08:17:48 Wed 16 14 9 18 14 8 8 73
15/01/2014 08:18 15-Jan-2014 08:18:48 Wed 16 14 10 18 14 9 8 74
15/01/2014 08:19 15-Jan-2014 08:19:48 Wed 16 15 10 20 17 11 8 76
15/01/2014 08:20 15-Jan-2014 08:20:48 Wed 16 14 8 16 14 9 8 71
15/01/2014 08:21 15-Jan-2014 08:21:48 Wed 15 14 9 16 13 8 9 69
15/01/2014 08:22 15-Jan-2014 08:22:48 Wed 14 13 8 15 13 8 9 67
15/01/2014 08:23 15-Jan-2014 08:23:48 Wed 15 13 8 15 13 8 9 64
15/01/2014 08:24 15-Jan-2014 08:24:48 Wed 14 12 8 14 12 8 9 63
15/01/2014 08:25 15-Jan-2014 08:25:48 Wed 16 14 9 17 14 9 9 65
15/01/2014 08:26 15-Jan-2014 08:26:48 Wed 16 14 9 19 14 9 8 67
15/01/2014 08:27 15-Jan-2014 08:27:48 Wed 16 14 8 19 14 9 8 71
15/01/2014 08:28 15-Jan-2014 08:28:48 Wed 16 14 8 17 14 8 8 70
15/01/2014 08:29 15-Jan-2014 08:29:48 Wed 16 14 8 18 14 8 8 72
15/01/2014 08:30 15-Jan-2014 08:30:48 Wed 16 14 9 21 17 12 8 74
15/01/2014 08:31 15-Jan-2014 08:31:48 Wed 16 14 10 18 15 10 8 74
15/01/2014 08:32 15-Jan-2014 08:32:48 Wed 16 14 10 19 14 9 8 73
15/01/2014 08:33 15-Jan-2014 08:33:48 Wed 16 15 10 19 14 10 8 74
15/01/2014 08:34 15-Jan-2014 08:34:48 Wed 17 16 11 18 16 11 8 73
15/01/2014 08:35 15-Jan-2014 08:35:48 Wed 17 15 10 17 15 10 8 74
15/01/2014 08:36 15-Jan-2014 08:36:48 Wed 16 15 10 17 15 10 8 74
15/01/2014 08:37 15-Jan-2014 08:37:48 Wed 16 14 9 16 14 9 9 68
15/01/2014 08:38 15-Jan-2014 08:38:48 Wed 17 15 11 17 15 11 8 71
15/01/2014 08:39 15-Jan-2014 08:39:48 Wed 16 15 10 18 14 9 9 67
15/01/2014 08:40 15-Jan-2014 08:40:48 Wed 16 14 9 19 14 8 8 71
15/01/2014 08:41 15-Jan-2014 08:41:48 Wed 16 14 9 18 14 9 8 72
15/01/2014 08:42 15-Jan-2014 08:42:48 Wed 15 14 8 17 14 8 8 72
15/01/2014 08:43 15-Jan-2014 08:43:48 Wed 15 14 8 17 14 9 8 74
15/01/2014 08:44 15-Jan-2014 08:44:48 Wed 15 14 8 16 13 9 8 72
15/01/2014 08:45 15-Jan-2014 08:45:48 Wed 15 14 9 19 16 9 8 75
15/01/2014 08:46 15-Jan-2014 08:46:48 Wed 15 13 8 15 13 8 8 73
15/01/2014 08:47 15-Jan-2014 08:47:48 Wed 15 13 8 15 13 8 8 74
15/01/2014 08:48 15-Jan-2014 08:48:48 Wed 15 13 9 15 13 8 9 68
15/01/2014 08:49 15-Jan-2014 08:49:48 Wed 15 13 8 14 13 8 8 69
15/01/2014 08:50 15-Jan-2014 08:50:48 Wed 15 13 10 16 13 9 8 75
15/01/2014 08:51 15-Jan-2014 08:51:48 Wed 15 13 8 15 13 9 8 73
15/01/2014 08:52 15-Jan-2014 08:52:48 Wed 15 13 8 15 13 9 8 75
15/01/2014 08:53 15-Jan-2014 08:53:48 Wed 15 13 9 15 13 8 8 74
15/01/2014 08:54 15-Jan-2014 08:54:48 Wed 16 15 11 16 14 10 8 72
15/01/2014 08:55 15-Jan-2014 08:55:48 Wed 16 15 10 16 14 10 8 72
15/01/2014 08:56 15-Jan-2014 08:56:48 Wed 17 16 11 17 16 11 8 74
15/01/2014 08:57 15-Jan-2014 08:57:48 Wed 17 16 11 17 15 11 9 68
15/01/2014 08:58 15-Jan-2014 08:58:48 Wed 17 16 12 17 16 12 9 66
15/01/2014 08:59 15-Jan-2014 08:59:48 Wed 17 16 11 17 16 11 9 68
15/01/2014 09:00 15-Jan-2014 09:00:48 Wed 17 15 10 17 15 10 8 71
15/01/2014 09:01 15-Jan-2014 09:01:48 Wed 16 15 9 16 15 9 8 71
15/01/2014 09:02 15-Jan-2014 09:02:48 Wed 16 14 10 16 14 9 8 71
15/01/2014 09:03 15-Jan-2014 09:03:48 Wed 15 14 8 16 14 8 8 72
15/01/2014 09:04 15-Jan-2014 09:04:48 Wed 16 14 9 15 14 9 8 74
15/01/2014 09:05 15-Jan-2014 09:05:48 Wed 15 13 8 15 13 8 8 74
15/01/2014 09:06 15-Jan-2014 09:06:48 Wed 15 13 8 16 13 8 8 73
15/01/2014 09:07 15-Jan-2014 09:07:48 Wed 15 13 8 15 13 8 8 73
15/01/2014 09:08 15-Jan-2014 09:08:48 Wed 15 13 8 15 13 8 8 74
15/01/2014 09:09 15-Jan-2014 09:09:48 Wed 15 13 8 14 13 8 8 74
15/01/2014 09:10 15-Jan-2014 09:10:48 Wed 14 13 8 16 13 8 8 76
15/01/2014 09:11 15-Jan-2014 09:11:48 Wed 14 13 8 18 15 8 8 75
15/01/2014 09:12 15-Jan-2014 09:12:48 Wed 14 12 8 15 12 8 8 76
15/01/2014 09:13 15-Jan-2014 09:13:48 Wed 14 12 8 14 11 8 9 71
15/01/2014 09:14 15-Jan-2014 09:14:48 Wed 14 13 8 15 13 8 8 73
15/01/2014 09:15 15-Jan-2014 09:15:48 Wed 14 13 8 14 12 8 8 74
15/01/2014 09:16 15-Jan-2014 09:16:48 Wed 14 13 8 14 12 8 8 74
15/01/2014 09:17 15-Jan-2014 09:17:48 Wed 14 12 8 15 11 8 8 74
15/01/2014 09:18 15-Jan-2014 09:18:48 Wed 13 12 9 13 12 8 8 74
15/01/2014 09:19 15-Jan-2014 09:19:48 Wed 13 12 8 14 11 8 8 76
15/01/2014 09:20 15-Jan-2014 09:20:48 Wed 13 11 8 13 11 8 8 75
15/01/2014 09:21 15-Jan-2014 09:21:48 Wed 13 11 8 16 13 8 8 76
15/01/2014 09:22 15-Jan-2014 09:22:48 Wed 13 12 8 13 11 8 8 76
15/01/2014 09:23 15-Jan-2014 09:23:48 Wed 13 12 8 14 11 8 8 76
15/01/2014 09:24 15-Jan-2014 09:24:48 Wed 13 11 8 18 16 8 8 77
15/01/2014 09:25 15-Jan-2014 09:25:48 Wed 13 11 8 20 18 9 8 74
15/01/2014 09:26 15-Jan-2014 09:26:48 Wed 13 11 8 12 10 8 9 71
15/01/2014 09:27 15-Jan-2014 09:27:48 Wed 12 10 8 13 10 8 9 69
15/01/2014 09:28 15-Jan-2014 09:28:48 Wed 13 11 8 13 10 8 9 67
15/01/2014 09:29 15-Jan-2014 09:29:48 Wed 13 12 8 14 11 8 8 69
15/01/2014 09:30 15-Jan-2014 09:30:48 Wed 13 12 9 13 11 8 9 69
15/01/2014 09:31 15-Jan-2014 09:31:48 Wed 14 12 8 14 12 8 9 69
15/01/2014 09:32 15-Jan-2014 09:32:48 Wed 14 13 8 18 15 9 8 72
15/01/2014 09:33 15-Jan-2014 09:33:48 Wed 15 13 9 15 14 9 8 71
15/01/2014 09:34 15-Jan-2014 09:34:48 Wed 15 13 9 15 14 8 8 71
15/01/2014 09:35 15-Jan-2014 09:35:48 Wed 15 13 9 15 13 8 8 73
15/01/2014 09:36 15-Jan-2014 09:36:48 Wed 15 14 9 15 13 8 8 74
15/01/2014 09:37 15-Jan-2014 09:37:48 Wed 15 13 8 15 13 9 8 73
15/01/2014 09:38 15-Jan-2014 09:38:48 Wed 15 13 8 15 13 8 9 71
15/01/2014 09:39 15-Jan-2014 09:39:48 Wed 15 13 8 15 13 8 9 72
15/01/2014 09:40 15-Jan-2014 09:40:48 Wed 15 13 8 14 12 8 9 71
15/01/2014 09:41 15-Jan-2014 09:41:48 Wed 15 14 10 15 13 8 9 69
15/01/2014 09:42 15-Jan-2014 09:42:48 Wed 17 16 11 16 15 11 9 67
15/01/2014 11:36 15-Jan-2014 11:36:29 Wed 9 13
15/01/2014 11:37 15-Jan-2014 11:37:29 Wed 20 19 14 20 18 14 16 32
15/01/2014 11:38 15-Jan-2014 11:38:29 Wed 19 18 13 16 34
15/01/2014 11:39 15-Jan-2014 11:39:29 Wed 19 17 11 18 16 10 16 37
15/01/2014 11:40 15-Jan-2014 11:40:29 Wed 18 16 10 18 16 10 14 41
15/01/2014 11:41 15-Jan-2014 11:41:29 Wed 17 16 8 18 15 8 12 46
15/01/2014 11:42 15-Jan-2014 11:42:29 Wed 17 15 10 17 14 9 13 40
15/01/2014 11:43 15-Jan-2014 11:43:29 Wed 17 15 9 17 36
15/01/2014 11:44 15-Jan-2014 11:44:29 Wed 17 14 9 16 13 8 17 43
15/01/2014 11:45 15-Jan-2014 11:45:29 Wed 17 15 8 17 14 8 15 38
15/01/2014 11:46 15-Jan-2014 11:46:29 Wed 16 14 9 16 14 8 12 47
15/01/2014 11:47 15-Jan-2014 11:47:29 Wed 18 15 8 16 13 8 12 52
15/01/2014 11:48 15-Jan-2014 11:48:29 Wed 19 16 10 17 15 9 11 53
15/01/2014 11:49 15-Jan-2014 11:49:29 Wed 19 16 11 17 15 9 11 54
15/01/2014 11:50 15-Jan-2014 11:50:29 Wed 18 16 11 17 15 9 10 56
15/01/2014 11:51 15-Jan-2014 11:51:29 Wed 18 16 11 17 14 8 10 55
15/01/2014 11:52 15-Jan-2014 11:52:29 Wed 17 15 9 17 14 9 10 56
15/01/2014 11:53 15-Jan-2014 11:53:29 Wed 17 15 9 18 14 10 10 58
15/01/2014 11:54 15-Jan-2014 11:54:29 Wed 17 15 10 17 14 9 10 58
15/01/2014 11:55 15-Jan-2014 11:55:29 Wed 17 15 8 16 13 8 10 61
15/01/2014 11:56 15-Jan-2014 11:56:29 Wed 16 14 8 19 13 8 10 61
15/01/2014 11:57 15-Jan-2014 11:57:29 Wed 16 14 8 18 13 9 9 62
15/01/2014 11:58 15-Jan-2014 11:58:29 Wed 16 14 8 17 13 8 9 63
15/01/2014 11:59 15-Jan-2014 11:59:29 Wed 16 13 9 16 12 8 9 64
15/01/2014 12:00 15-Jan-2014 12:00:29 Wed 16 13 8 16 12 8 9 65
15/01/2014 12:01 15-Jan-2014 12:01:29 Wed 18 14 9 15 12 8 9 66
15/01/2014 12:02 15-Jan-2014 12:02:29 Wed 18 14 8 17 13 8 9 67
15/01/2014 12:03 15-Jan-2014 12:03:29 Wed 18 14 9 15 12 8 9 67
15/01/2014 12:04 15-Jan-2014 12:04:29 Wed 17 13 8 15 12 8 9 64
15/01/2014 12:05 15-Jan-2014 12:05:29 Wed 14 12 8 14 12 8 10 61
15/01/2014 12:06 15-Jan-2014 12:06:29 Wed 13 11 8 13 10 8 10 60
15/01/2014 12:07 15-Jan-2014 12:07:29 Wed 14 12 8 14 12 8 10 59
15/01/2014 12:08 15-Jan-2014 12:08:29 Wed 13 11 8 13 9 8 10 58
15/01/2014 12:09 15-Jan-2014 12:09:29 Wed 13 11 8 14 11 8 10 56
15/01/2014 12:10 15-Jan-2014 12:10:29 Wed 13 10 8 15 9 8 10 55
15/01/2014 12:11 15-Jan-2014 12:11:29 Wed 13 11 8 14 9 8 10 54
15/01/2014 12:12 15-Jan-2014 12:12:29 Wed 13 10 8 14 10 8 10 53
15/01/2014 12:13 15-Jan-2014 12:13:29 Wed 14 13 8 16 12 8 9 56
15/01/2014 12:14 15-Jan-2014 12:14:29 Wed 15 13 8 15 13 8 10 55
15/01/2014 12:15 15-Jan-2014 12:15:29 Wed 14 12 8 15 12 8 11 53
15/01/2014 12:16 15-Jan-2014 12:16:29 Wed 14 13 8 15 11 8 9 60
15/01/2014 12:17 15-Jan-2014 12:17:29 Wed 15 13 8 17 13 8 9 62
15/01/2014 12:18 15-Jan-2014 12:18:29 Wed 15 13 9 17 12 8 9 65
15/01/2014 12:19 15-Jan-2014 12:19:29 Wed 15 13 8 17 12 8 9 65
15/01/2014 12:20 15-Jan-2014 12:20:29 Wed 15 13 8 15 12 8 9 63
15/01/2014 12:21 15-Jan-2014 12:21:29 Wed 15 13 8 15 12 8 9 63
15/01/2014 12:22 15-Jan-2014 12:22:29 Wed 15 14 9 15 13 8 9 65
15/01/2014 12:23 15-Jan-2014 12:23:29 Wed 16 14 8 16 12 8 9 67
15/01/2014 12:24 15-Jan-2014 12:24:29 Wed 16 13 8 16 12 8 9 67
15/01/2014 12:25 15-Jan-2014 12:25:29 Wed 16 14 9 16 12 8 9 67
15/01/2014 12:26 15-Jan-2014 12:26:29 Wed 16 13 8 17 12 8 8 70
15/01/2014 12:27 15-Jan-2014 12:27:29 Wed 16 13 8 18 13 8 8 71
15/01/2014 12:28 15-Jan-2014 12:28:29 Wed 15 13 8 16 13 8 8 72
15/01/2014 12:29 15-Jan-2014 12:29:29 Wed 15 13 8 15 12 8 8 72
15/01/2014 12:30 15-Jan-2014 12:30:29 Wed 14 12 8 18 12 9 8 71
15/01/2014 12:31 15-Jan-2014 12:31:29 Wed 14 13 8 17 12 9 8 72
15/01/2014 12:32 15-Jan-2014 12:32:29 Wed 15 14 8 15 14 10 8 72
15/01/2014 12:33 15-Jan-2014 12:33:29 Wed 15 14 9 15 14 10 8 71
15/01/2014 12:34 15-Jan-2014 12:34:29 Wed 15 13 9 15 13 8 9 66
15/01/2014 12:35 15-Jan-2014 12:35:29 Wed 15 14 9 16 13 9 8 70
15/01/2014 12:36 15-Jan-2014 12:36:29 Wed 15 14 9 16 13 8 8 69
15/01/2014 12:37 15-Jan-2014 12:37:29 Wed 15 13 9 15 13 8 8 69
15/01/2014 12:38 15-Jan-2014 12:38:29 Wed 15 14 9 16 14 9 8 71
15/01/2014 12:39 15-Jan-2014 12:39:29 Wed 15 13 8 15 13 8 8 70
15/01/2014 12:40 15-Jan-2014 12:40:29 Wed 14 13 8 16 13 8 8 71
15/01/2014 12:41 15-Jan-2014 12:41:29 Wed 14 12 8 15 12 8 8 71
15/01/2014 12:42 15-Jan-2014 12:42:29 Wed 14 12 8 17 13 8 8 71
15/01/2014 12:43 15-Jan-2014 12:43:29 Wed 14 13 8 16 12 8 8 72
15/01/2014 12:44 15-Jan-2014 12:44:29 Wed 14 13 8 15 12 8 8 73
15/01/2014 12:45 15-Jan-2014 12:45:29 Wed 14 13 8 15 12 8 8 73
15/01/2014 12:46 15-Jan-2014 12:46:29 Wed 14 12 8 16 13 8 8 74
15/01/2014 12:47 15-Jan-2014 12:47:29 Wed 14 12 8 17 12 8 8 74
15/01/2014 12:48 15-Jan-2014 12:48:29 Wed 14 13 9 14 12 8 8 73
15/01/2014 12:49 15-Jan-2014 12:49:29 Wed 14 13 8 18 12 8 8 73
15/01/2014 12:50 15-Jan-2014 12:50:29 Wed 14 13 8 16 13 8 8 73
15/01/2014 12:51 15-Jan-2014 12:51:29 Wed 14 13 9 14 13 8 8 69
15/01/2014 12:52 15-Jan-2014 12:52:29 Wed 14 13 9 14 12 8 8 71
15/01/2014 12:53 15-Jan-2014 12:53:29 Wed 14 13 8 15 12 8 8 73
15/01/2014 12:54 15-Jan-2014 12:54:29 Wed 14 13 8 14 12 8 9 69
15/01/2014 12:55 15-Jan-2014 12:55:29 Wed 15 13 8 14 12 8 9 71
15/01/2014 13:37 15-Jan-2014 13:37:11 Wed 13 33
15/01/2014 13:38 15-Jan-2014 13:38:11 Wed 19 17 11 18 17 11 13 52
15/01/2014 13:39 15-Jan-2014 13:39:11 Wed 18 16 9 18 16 8 11 57
15/01/2014 13:40 15-Jan-2014 13:40:11 Wed 18 16 8 17 15 9 10 59
15/01/2014 13:41 15-Jan-2014 13:41:11 Wed 18 15 8 17 14 8 10 60
15/01/2014 13:42 15-Jan-2014 13:42:11 Wed 17 15 8 16 14 8 10 63
15/01/2014 13:43 15-Jan-2014 13:43:11 Wed 20 15 8 17 13 8 10 62
15/01/2014 13:44 15-Jan-2014 13:44:11 Wed 18 15 9 16 14 9 10 60
15/01/2014 13:45 15-Jan-2014 13:45:11 Wed 16 15 9 16 14 9 11 57
15/01/2014 13:46 15-Jan-2014 13:46:11 Wed 16 14 8 16 13 8 12 55
15/01/2014 13:47 15-Jan-2014 13:47:11 Wed 15 13 8 16 13 8 12 54
15/01/2014 13:48 15-Jan-2014 13:48:11 Wed 15 13 9 15 12 8 11 52
15/01/2014 13:49 15-Jan-2014 13:49:11 Wed 15 13 8 15 12 8 11 52
15/01/2014 13:50 15-Jan-2014 13:50:11 Wed 15 13 8 15 13 9 11 50
15/01/2014 13:51 15-Jan-2014 13:51:11 Wed 15 13 9 16 13 8 11 49
15/01/2014 13:52 15-Jan-2014 13:52:11 Wed 15 13 8 15 12 8 11 49
15/01/2014 13:53 15-Jan-2014 13:53:11 Wed 16 14 9 16 13 8 10 53
15/01/2014 13:54 15-Jan-2014 13:54:11 Wed 16 15 8 17 14 9 12 48
15/01/2014 13:55 15-Jan-2014 13:55:11 Wed 16 14 8 16 14 10 12 48
15/01/2014 13:56 15-Jan-2014 13:56:11 Wed 16 14 8 15 13 8 11 52
15/01/2014 13:57 15-Jan-2014 13:57:11 Wed 16 14 8 16 14 9 10 54
15/01/2014 13:58 15-Jan-2014 13:58:11 Wed 16 14 9 16 13 9 10 56
15/01/2014 13:59 15-Jan-2014 13:59:11 Wed 16 14 8 16 13 8 10 58
15/01/2014 14:00 15-Jan-2014 14:00:11 Wed 16 14 8 16 13 8 10 60
15/01/2014 14:01 15-Jan-2014 14:01:11 Wed 16 14 8 15 13 8 9 61
15/01/2014 14:02 15-Jan-2014 14:02:11 Wed 16 14 9 17 13 8 9 62
15/01/2014 14:03 15-Jan-2014 14:03:11 Wed 16 14 8 18 14 9 9 62
15/01/2014 14:04 15-Jan-2014 14:04:11 Wed 16 14 9 17 13 8 9 62
15/01/2014 14:05 15-Jan-2014 14:05:11 Wed 16 14 8 16 13 8 9 63
15/01/2014 14:06 15-Jan-2014 14:06:11 Wed 16 14 8 17 13 8 9 63
15/01/2014 14:07 15-Jan-2014 14:07:11 Wed 15 13 8 15 13 8 10 59
15/01/2014 14:08 15-Jan-2014 14:08:11 Wed 15 12 8 15 12 8 9 62
15/01/2014 14:09 15-Jan-2014 14:09:11 Wed 15 13 8 15 12 8 9 64
15/01/2014 14:10 15-Jan-2014 14:10:11 Wed 16 13 8 15 12 8 9 65
15/01/2014 14:11 15-Jan-2014 14:11:11 Wed 17 13 8 17 12 8 9 66
15/01/2014 14:12 15-Jan-2014 14:12:11 Wed 16 14 8 17 12 8 9 67
15/01/2014 14:13 15-Jan-2014 14:13:11 Wed 16 13 8 17 12 8 8 68
15/01/2014 14:14 15-Jan-2014 14:14:11 Wed 16 13 8 15 12 8 9 65
15/01/2014 14:15 15-Jan-2014 14:15:11 Wed 16 13 8 16 12 8 9 67
15/01/2014 14:16 15-Jan-2014 14:16:11 Wed 15 13 8 17 13 8 9 69
15/01/2014 14:17 15-Jan-2014 14:17:11 Wed 16 14 10 16 13 10 9 65
15/01/2014 14:18 15-Jan-2014 14:18:11 Wed 16 14 9 18 14 8 9 68
15/01/2014 14:19 15-Jan-2014 14:19:11 Wed 15 13 8 15 13 8 9 68
15/01/2014 14:20 15-Jan-2014 14:20:11 Wed 15 13 8 15 13 8 9 69
15/01/2014 14:35 15-Jan-2014 14:35:32 Wed 12 56
15/01/2014 14:36 15-Jan-2014 14:36:32 Wed 19 18 12 19 17 11 12 54
15/01/2014 14:37 15-Jan-2014 14:37:32 Wed 18 17 12 18 16 11 10 61
15/01/2014 14:38 15-Jan-2014 14:38:32 Wed 18 16 10 18 15 10 10 62
15/01/2014 14:39 15-Jan-2014 14:39:32 Wed 19 16 9 17 15 8 9 67
15/01/2014 14:40 15-Jan-2014 14:40:32 Wed 19 16 8 17 14 8 9 66
15/01/2014 14:41 15-Jan-2014 14:41:32 Wed 19 15 9 16 14 9 9 65
15/01/2014 14:42 15-Jan-2014 14:42:32 Wed 17 15 8 16 14 9 9 64
15/01/2014 14:43 15-Jan-2014 14:43:32 Wed 16 14 8 17 14 9 10 60
15/01/2014 14:44 15-Jan-2014 14:44:32 Wed 16 14 8 16 14 8 10 58
15/01/2014 14:45 15-Jan-2014 14:45:32 Wed 16 14 8 16 14 8 10 57
15/01/2014 14:46 15-Jan-2014 14:46:32 Wed 16 14 8 16 13 8 10 55
15/01/2014 14:47 15-Jan-2014 14:47:32 Wed 16 14 9 17 14 8 10 54
15/01/2014 14:48 15-Jan-2014 14:48:32 Wed 16 14 9 16 13 8 10 53
15/01/2014 14:49 15-Jan-2014 14:49:32 Wed 16 14 9 16 14 10 10 52
15/01/2014 14:50 15-Jan-2014 14:50:32 Wed 16 14 8 16 14 10 10 51
15/01/2014 14:51 15-Jan-2014 14:51:32 Wed 16 14 8 16 13 8 10 50
15/01/2014 14:52 15-Jan-2014 14:52:32 Wed 16 14 8 16 13 9 10 50
15/01/2014 14:53 15-Jan-2014 14:53:32 Wed 16 14 9 16 13 8 10 50
15/01/2014 14:54 15-Jan-2014 14:54:32 Wed 16 14 8 16 13 8 10 49
15/01/2014 14:55 15-Jan-2014 14:55:32 Wed 16 14 9 16 13 8 10 49
15/01/2014 14:56 15-Jan-2014 14:56:32 Wed 16 14 8 16 13 8 10 48
15/01/2014 14:57 15-Jan-2014 14:57:32 Wed 16 14 8 16 13 8 10 47
15/01/2014 14:58 15-Jan-2014 14:58:32 Wed 16 14 10 16 13 8 10 47
15/01/2014 14:59 15-Jan-2014 14:59:32 Wed 16 14 8 16 13 8 10 46
15/01/2014 15:00 15-Jan-2014 15:00:32 Wed 16 14 9 16 13 9 10 46
15/01/2014 15:01 15-Jan-2014 15:01:32 Wed 16 14 8 16 13 8 10 45
15/01/2014 15:02 15-Jan-2014 15:02:32 Wed 16 14 8 16 13 8 10 44
15/01/2014 15:03 15-Jan-2014 15:03:32 Wed 15 14 8 16 13 8 10 43
15/01/2014 15:04 15-Jan-2014 15:04:32 Wed 16 14 8 16 13 8 10 43
15/01/2014 15:05 15-Jan-2014 15:05:32 Wed 15 14 8 16 13 8 11 42
15/01/2014 15:06 15-Jan-2014 15:06:32 Wed 15 14 8 16 13 8 11 42
15/01/2014 15:07 15-Jan-2014 15:07:32 Wed 15 14 9 15 12 8 11 41
15/01/2014 15:08 15-Jan-2014 15:08:32 Wed 16 14 8 16 13 8 11 41
15/01/2014 15:09 15-Jan-2014 15:09:32 Wed 16 13 8 11 41
15/01/2014 15:10 15-Jan-2014 15:10:32 Wed 15 13 8 15 13 8 11 40
15/01/2014 15:11 15-Jan-2014 15:11:32 Wed 19 18 12 18 15 10 10 41
15/01/2014 15:12 15-Jan-2014 15:12:32 Wed 18 17 9 19 16 11 11 41
15/01/2014 15:13 15-Jan-2014 15:13:32 Wed 18 17 10 12 41
15/01/2014 15:14 15-Jan-2014 15:14:32 Wed 18 16 9 18 15 8 12 42
15/01/2014 15:15 15-Jan-2014 15:15:32 Wed 19 17 10 18 16 9 11 42
15/01/2014 15:16 15-Jan-2014 15:16:32 Wed 18 17 9 12 41
15/01/2014 15:17 15-Jan-2014 15:17:32 Wed 18 17 9 12 41
15/01/2014 15:18 15-Jan-2014 15:18:32 Wed 18 17 8 12 40
15/01/2014 19:17 15-Jan-2014 19:17:51 Wed 14 8
15/01/2014 19:18 15-Jan-2014 19:18:51 Wed 19 18 13 26 16
15/01/2014 19:19 15-Jan-2014 19:19:51 Wed 19 17 12 25 16
15/01/2014 19:20 15-Jan-2014 19:20:51 Wed 18 17 10 24 16
15/01/2014 19:21 15-Jan-2014 19:21:51 Wed 20 18 13 20 18 12 20 27
15/01/2014 19:22 15-Jan-2014 19:22:51 Wed 19 18 10 19 17 11 17 30
15/01/2014 19:23 15-Jan-2014 19:23:51 Wed 19 17 8 18 16 8 16 29
15/01/2014 19:24 15-Jan-2014 19:24:51 Wed 19 17 12 19 16 10 14 33
15/01/2014 19:25 15-Jan-2014 19:25:51 Wed 18 16 10 18 16 10 15 31
15/01/2014 19:26 15-Jan-2014 19:26:51 Wed 18 16 11 18 15 9 17 35
15/01/2014 19:27 15-Jan-2014 19:27:51 Wed 18 15 8 17 14 8 17 42
15/01/2014 19:28 15-Jan-2014 19:28:51 Wed 25 18 8 17 14 8 17 44
15/01/2014 19:29 15-Jan-2014 19:29:51 Wed 23 17 9 17 14 8 15 50
15/01/2014 19:30 15-Jan-2014 19:30:51 Wed 24 18 12 19 15 8 12 52
15/01/2014 19:31 15-Jan-2014 19:31:51 Wed 24 19 12 19 15 9 11 53
15/01/2014 19:32 15-Jan-2014 19:32:51 Wed 24 18 12 18 15 9 11 54
15/01/2014 19:33 15-Jan-2014 19:33:51 Wed 23 17 10 18 15 9 10 56
15/01/2014 19:34 15-Jan-2014 19:34:51 Wed 23 17 10 18 15 8 10 58
15/01/2014 19:35 15-Jan-2014 19:35:51 Wed 21 16 9 17 14 8 10 58
15/01/2014 19:36 15-Jan-2014 19:36:51 Wed 18 15 10 17 14 9 11 54
15/01/2014 19:37 15-Jan-2014 19:37:51 Wed 18 16 11 18 14 10 10 60
15/01/2014 19:38 15-Jan-2014 19:38:51 Wed 18 15 9 18 14 9 10 61
15/01/2014 19:39 15-Jan-2014 19:39:51 Wed 17 15 9 19 14 8 10 63
15/01/2014 19:40 15-Jan-2014 19:40:51 Wed 17 15 9 19 14 8 9 64
15/01/2014 19:41 15-Jan-2014 19:41:51 Wed 17 15 8 17 14 8 9 63
15/01/2014 19:42 15-Jan-2014 19:42:51 Wed 17 14 9 19 14 8 9 64
15/01/2014 19:43 15-Jan-2014 19:43:51 Wed 17 15 9 17 14 10 9 60
15/01/2014 19:44 15-Jan-2014 19:44:51 Wed 16 15 8 16 13 8 10 60
15/01/2014 19:45 15-Jan-2014 19:45:51 Wed 16 14 8 15 13 8 10 60
15/01/2014 19:46 15-Jan-2014 19:46:51 Wed 16 14 8 16 13 8 11 57
15/01/2014 19:47 15-Jan-2014 19:47:51 Wed 15 13 8 16 13 8 11 56
15/01/2014 19:48 15-Jan-2014 19:48:51 Wed 15 14 9 16 14 10 11 55
15/01/2014 19:49 15-Jan-2014 19:49:51 Wed 15 14 8 15 13 9 10 57
15/01/2014 19:50 15-Jan-2014 19:50:51 Wed 15 13 8 16 13 8 11 53
15/01/2014 19:51 15-Jan-2014 19:51:51 Wed 15 13 8 15 12 8 11 52
15/01/2014 19:52 15-Jan-2014 19:52:51 Wed 15 13 8 17 12 8 10 53
15/01/2014 19:53 15-Jan-2014 19:53:51 Wed 14 13 8 15 13 8 11 51
15/01/2014 19:54 15-Jan-2014 19:54:51 Wed 14 12 9 15 13 8 11 50
15/01/2014 19:55 15-Jan-2014 19:55:51 Wed 14 12 8 14 10 8 11 50
15/01/2014 19:56 15-Jan-2014 19:56:51 Wed 14 12 8 15 11 8 11 49
15/01/2014 19:57 15-Jan-2014 19:57:51 Wed 14 12 9 15 11 8 11 49
15/01/2014 19:58 15-Jan-2014 19:58:51 Wed 14 12 8 14 12 8 11 48
15/01/2014 19:59 15-Jan-2014 19:59:51 Wed 14 13 10 15 12 8 12 47
15/01/2014 20:00 15-Jan-2014 20:00:51 Wed 14 13 8 15 12 8 11 47
15/01/2014 20:01 15-Jan-2014 20:01:51 Wed 14 12 8 14 11 9 12 46
15/01/2014 20:02 15-Jan-2014 20:02:51 Wed 14 13 9 14 12 8 12 46
15/01/2014 20:03 15-Jan-2014 20:03:51 Wed 14 13 8 14 11 8 12 46
15/01/2014 20:04 15-Jan-2014 20:04:51 Wed 14 13 9 12 45
15/01/2014 20:05 15-Jan-2014 20:05:51 Wed 14 13 8 14 12 8 12 44
15/01/2014 20:06 15-Jan-2014 20:06:51 Wed 14 13 8 14 12 8 12 44
15/01/2014 20:07 15-Jan-2014 20:07:51 Wed 14 13 8 14 13 8 12 43
15/01/2014 20:08 15-Jan-2014 20:08:51 Wed 15 13 8 13 11 8 11 45
15/01/2014 20:09 15-Jan-2014 20:09:51 Wed 18 17 11 18 16 10 10 50
15/01/2014 20:10 15-Jan-2014 20:10:51 Wed 18 16 8 18 16 9 9 53
15/01/2014 20:11 15-Jan-2014 20:11:51 Wed 18 16 8 18 15 8 10 57
15/01/2014 20:12 15-Jan-2014 20:12:51 Wed 18 16 8 18 15 8 10 57
15/01/2014 20:13 15-Jan-2014 20:13:51 Wed 17 15 8 17 14 8 9 60
15/01/2014 20:14 15-Jan-2014 20:14:51 Wed 17 15 8 18 14 8 9 61
15/01/2014 20:15 15-Jan-2014 20:15:51 Wed 17 15 9 18 14 8 9 62
15/01/2014 20:16 15-Jan-2014 20:16:51 Wed 17 14 8 19 14 8 9 65
15/01/2014 20:17 15-Jan-2014 20:17:51 Wed 16 14 8 18 14 8 9 64
15/01/2014 20:18 15-Jan-2014 20:18:51 Wed 17 14 8 17 13 8 9 65
15/01/2014 20:19 15-Jan-2014 20:19:51 Wed 20 15 8 19 13 8 9 66
15/01/2014 20:20 15-Jan-2014 20:20:51 Wed 20 15 8 19 13 8 9 68
15/01/2014 20:21 15-Jan-2014 20:21:51 Wed 17 14 8 15 12 8 10 62
15/01/2014 20:22 15-Jan-2014 20:22:51 Wed 17 14 8 16 13 8 9 66
15/01/2014 20:23 15-Jan-2014 20:23:51 Wed 21 15 8 18 13 8 9 68
15/01/2014 20:24 15-Jan-2014 20:24:51 Wed 20 15 8 18 13 8 8 70
15/01/2014 20:25 15-Jan-2014 20:25:51 Wed 20 14 8 17 13 9 8 71
15/01/2014 20:26 15-Jan-2014 20:26:51 Wed 18 14 8 18 13 8 8 72
15/01/2014 20:27 15-Jan-2014 20:27:51 Wed 17 14 8 18 13 8 8 73
15/01/2014 20:28 15-Jan-2014 20:28:51 Wed 16 14 9 20 16 9 8 73
15/01/2014 20:29 15-Jan-2014 20:29:51 Wed 16 13 8 17 12 8 8 72
15/01/2014 20:30 15-Jan-2014 20:30:51 Wed 15 13 8 18 12 8 8 73
15/01/2014 20:31 15-Jan-2014 20:31:51 Wed 15 13 8 18 13 8 8 74
15/01/2014 20:32 15-Jan-2014 20:32:51 Wed 15 13 8 18 13 8 8 75
15/01/2014 20:33 15-Jan-2014 20:33:51 Wed 15 13 9 20 14 9 8 75
15/01/2014 20:34 15-Jan-2014 20:34:51 Wed 15 13 8 1 1 1 8 74
15/01/2014 20:35 15-Jan-2014 20:35:51 Wed 16 14 9 1 1 1 8 75
15/01/2014 20:36 15-Jan-2014 20:36:51 Wed 16 14 9 1 1 1 8 74
15/01/2014 20:37 15-Jan-2014 20:37:51 Wed 16 14 8 1 1 1 8 74
15/01/2014 20:38 15-Jan-2014 20:38:51 Wed 15 13 8 1 1 1 8 76
15/01/2014 20:39 15-Jan-2014 20:39:51 Wed 15 14 8 1 1 1 8 75
15/01/2014 20:40 15-Jan-2014 20:40:51 Wed 15 13 8 1 1 1 8 76
15/01/2014 20:41 15-Jan-2014 20:41:51 Wed 15 13 8 17 15 8 8 76
15/01/2014 20:42 15-Jan-2014 20:42:51 Wed 15 13 8 19 16 8 8 78
15/01/2014 20:43 15-Jan-2014 20:43:51 Wed 15 12 8 18 15 8 8 77
15/01/2014 20:44 15-Jan-2014 20:44:51 Wed 14 12 8 15 12 8 8 76
15/01/2014 20:45 15-Jan-2014 20:45:51 Wed 14 12 8 14 12 8 8 77
15/01/2014 20:46 15-Jan-2014 20:46:51 Wed 14 12 8 17 13 8 8 78
15/01/2014 20:47 15-Jan-2014 20:47:51 Wed 15 12 8 21 19 8 8 79
15/01/2014 20:48 15-Jan-2014 20:48:51 Wed 15 13 8 21 18 11 8 80
15/01/2014 20:49 15-Jan-2014 20:49:51 Wed 15 13 8 14 12 8 8 79
15/01/2014 20:50 15-Jan-2014 20:50:51 Wed 15 13 8 21 18 9 8 81
15/01/2014 20:51 15-Jan-2014 20:51:51 Wed 15 13 8 16 12 8 8 81
15/01/2014 20:52 15-Jan-2014 20:52:51 Wed 15 12 8 14 12 8 8 80
15/01/2014 20:53 15-Jan-2014 20:53:51 Wed 14 12 8 14 11 8 9 74
15/01/2014 20:54 15-Jan-2014 20:54:51 Wed 13 11 8 14 11 8 9 72
15/01/2014 20:55 15-Jan-2014 20:55:51 Wed 13 11 8 13 11 8 9 70
15/01/2014 20:56 15-Jan-2014 20:56:51 Wed 12 10 8 16 10 8 9 68
15/01/2014 20:57 15-Jan-2014 20:57:51 Wed 13 11 8 13 10 8 9 66
15/01/2014 20:58 15-Jan-2014 20:58:51 Wed 13 11 8 13 9 8 9 65
15/01/2014 20:59 15-Jan-2014 20:59:51 Wed 12 11 8 14 11 8 9 63
15/01/2014 21:00 15-Jan-2014 21:00:51 Wed 13 11 8 13 10 8 9 62
15/01/2014 21:01 15-Jan-2014 21:01:51 Wed 13 11 8 13 11 8 9 60
15/01/2014 21:02 15-Jan-2014 21:02:51 Wed 14 12 8 14 11 8 9 58
15/01/2014 21:03 15-Jan-2014 21:03:51 Wed 14 13 8 14 12 8 9 57
15/01/2014 21:04 15-Jan-2014 21:04:51 Wed 14 13 8 14 13 10 9 56
15/01/2014 21:05 15-Jan-2014 21:05:51 Wed 14 13 8 15 12 8 9 55
15/01/2014 21:06 15-Jan-2014 21:06:51 Wed 20 18 11 19 17 11 9 55
15/01/2014 21:07 15-Jan-2014 21:07:51 Wed 18 16 8 18 16 10 9 59
15/01/2014 21:08 15-Jan-2014 21:08:51 Wed 17 16 8 19 15 9 9 64
15/01/2014 21:09 15-Jan-2014 21:09:51 Wed 17 15 8 18 15 8 9 67
15/01/2014 21:10 15-Jan-2014 21:10:51 Wed 18 15 8 18 14 8 9 68
15/01/2014 21:11 15-Jan-2014 21:11:51 Wed 18 15 8 19 14 8 8 70
15/01/2014 21:12 15-Jan-2014 21:12:51 Wed 18 15 8 19 14 8 8 70
15/01/2014 21:13 15-Jan-2014 21:13:51 Wed 17 15 8 18 13 8 8 72
15/01/2014 21:14 15-Jan-2014 21:14:51 Wed 17 15 8 17 14 8 9 68
15/01/2014 21:15 15-Jan-2014 21:15:51 Wed 16 14 8 17 14 8 8 70
15/01/2014 21:16 15-Jan-2014 21:16:51 Wed 16 14 8 16 14 8 9 68
15/01/2014 21:17 15-Jan-2014 21:17:51 Wed 16 14 8 15 13 8 9 68
15/01/2014 21:18 15-Jan-2014 21:18:51 Wed 16 14 8 15 13 8 9 70
15/01/2014 21:19 15-Jan-2014 21:19:51 Wed 15 13 8 15 13 8 9 71
15/01/2014 21:20 15-Jan-2014 21:20:51 Wed 15 13 8 15 13 8 9 67
15/01/2014 21:21 15-Jan-2014 21:21:51 Wed 15 13 8 15 13 9 9 66
15/01/2014 21:22 15-Jan-2014 21:22:51 Wed 15 13 8 15 13 8 9 67
15/01/2014 21:23 15-Jan-2014 21:23:51 Wed 15 13 8 15 13 8 9 67
15/01/2014 21:24 15-Jan-2014 21:24:51 Wed 15 13 8 15 12 8 9 68
15/01/2014 21:25 15-Jan-2014 21:25:51 Wed 14 13 8 15 12 8 10 64
15/01/2014 21:26 15-Jan-2014 21:26:51 Wed 15 14 10 16 13 9 10 62
15/01/2014 21:27 15-Jan-2014 21:27:51 Wed 16 15 9 16 15 11 9 60
15/01/2014 21:28 15-Jan-2014 21:28:51 Wed 16 15 10 16 15 10 10 58
15/01/2014 21:29 15-Jan-2014 21:29:51 Wed 17 16 11 16 15 9 9 57
15/01/2014 22:24 15-Jan-2014 22:24:24 Wed 9 24
15/01/2014 22:25 15-Jan-2014 22:25:24 Wed 20 18 13 20 18 13 15 39
15/01/2014 22:26 15-Jan-2014 22:26:24 Wed 19 17 11 19 17 10 13 44
15/01/2014 22:27 15-Jan-2014 22:27:24 Wed 18 17 9 18 16 8 13 47
15/01/2014 22:28 15-Jan-2014 22:28:24 Wed 18 16 11 18 16 10 12 50
15/01/2014 22:29 15-Jan-2014 22:29:24 Wed 21 18 13 18 16 10 13 48
15/01/2014 22:30 15-Jan-2014 22:30:24 Wed 23 18 13 18 15 11 13 52
15/01/2014 22:31 15-Jan-2014 22:31:24 Wed 19 16 11 17 15 8 13 55
15/01/2014 22:32 15-Jan-2014 22:32:24 Wed 19 15 10 16 14 8 12 56
15/01/2014 22:33 15-Jan-2014 22:33:24 Wed 23 16 8 17 13 8 12 59
15/01/2014 22:34 15-Jan-2014 22:34:24 Wed 23 17 10 17 14 8 11 63
15/01/2014 22:35 15-Jan-2014 22:35:24 Wed 19 16 10 19 15 9 10 64
15/01/2014 22:36 15-Jan-2014 22:36:24 Wed 18 16 10 19 15 8 10 62
15/01/2014 22:37 15-Jan-2014 22:37:24 Wed 18 16 11 17 14 8 10 60
15/01/2014 22:38 15-Jan-2014 22:38:24 Wed 17 15 9 17 14 8 13 57
15/01/2014 22:39 15-Jan-2014 22:39:24 Wed 17 16 11 17 15 11 11 56
15/01/2014 22:40 15-Jan-2014 22:40:24 Wed 17 15 10 17 15 10 12 54
15/01/2014 22:41 15-Jan-2014 22:41:24 Wed 16 14 9 16 14 8 11 56
15/01/2014 22:42 15-Jan-2014 22:42:24 Wed 17 15 9 16 14 9 10 57
15/01/2014 22:43 15-Jan-2014 22:43:24 Wed 16 15 8 16 14 8 10 62
15/01/2014 22:44 15-Jan-2014 22:44:24 Wed 16 14 9 16 14 8 10 62
15/01/2014 22:45 15-Jan-2014 22:45:24 Wed 16 14 9 16 13 8 10 63
15/01/2014 22:46 15-Jan-2014 22:46:24 Wed 20 15 9 17 13 8 9 66
15/01/2014 22:47 15-Jan-2014 22:47:24 Wed 21 15 8 17 13 8 9 67
15/01/2014 22:48 15-Jan-2014 22:48:24 Wed 21 15 8 16 13 8 9 67
15/01/2014 22:49 15-Jan-2014 22:49:24 Wed 22 15 8 15 12 8 10 65
15/01/2014 22:50 15-Jan-2014 22:50:24 Wed 20 14 8 17 12 8 10 67
15/01/2014 22:51 15-Jan-2014 22:51:24 Wed 18 13 8 14 12 8 10 63
15/01/2014 22:52 15-Jan-2014 22:52:24 Wed 14 13 8 15 12 8 10 61
15/01/2014 22:53 15-Jan-2014 22:53:24 Wed 15 13 8 15 13 8 10 59
15/01/2014 22:54 15-Jan-2014 22:54:24 Wed 19 17 10 19 17 10 10 63
15/01/2014 22:55 15-Jan-2014 22:55:24 Wed 19 17 8 18 16 9 10 65
15/01/2014 22:56 15-Jan-2014 22:56:24 Wed 19 16 8 18 15 8 9 67
15/01/2014 22:57 15-Jan-2014 22:57:24 Wed 18 16 8 17 15 8 10 64
15/01/2014 22:58 15-Jan-2014 22:58:24 Wed 17 15 8 17 14 8 10 66
15/01/2014 22:59 15-Jan-2014 22:59:24 Wed 17 14 8 16 13 8 10 67
15/01/2014 23:00 15-Jan-2014 23:00:24 Wed 17 14 8 16 13 8 10 67
15/01/2014 23:01 15-Jan-2014 23:01:24 Wed 17 14 8 17 13 8 9 72
15/01/2014 23:02 15-Jan-2014 23:02:24 Wed 16 14 8 18 13 8 9 73
15/01/2014 23:03 15-Jan-2014 23:03:24 Wed 16 15 8 19 15 8 9 71
15/01/2014 23:04 15-Jan-2014 23:04:24 Wed 16 14 8 17 14 8 9 71
15/01/2014 23:05 15-Jan-2014 23:05:24 Wed 16 14 8 18 14 8 8 71
15/01/2014 23:06 15-Jan-2014 23:06:24 Wed 16 14 8 17 14 8 8 71
15/01/2014 23:07 15-Jan-2014 23:07:24 Wed 16 14 8 18 13 8 8 74
15/01/2014 23:08 15-Jan-2014 23:08:24 Wed 16 14 8 16 13 8 8 72
15/01/2014 23:09 15-Jan-2014 23:09:24 Wed 16 14 8 20 15 8 8 74
15/01/2014 23:10 15-Jan-2014 23:10:24 Wed 15 14 8 17 13 8 8 75
15/01/2014 23:11 15-Jan-2014 23:11:24 Wed 15 13 8 17 13 8 8 75
15/01/2014 23:12 15-Jan-2014 23:12:24 Wed 15 13 8 15 13 8 9 70
15/01/2014 23:13 15-Jan-2014 23:13:24 Wed 15 13 8 15 12 8 9 69
15/01/2014 23:14 15-Jan-2014 23:14:24 Wed 18 16 9 18 16 9 8 73
15/01/2014 23:15 15-Jan-2014 23:15:24 Wed 18 16 8 18 16 8 8 73
15/01/2014 23:16 15-Jan-2014 23:16:24 Wed 17 16 8 19 16 8 8 75
15/01/2014 23:17 15-Jan-2014 23:17:24 Wed 17 15 8 17 15 8 8 75
15/01/2014 23:18 15-Jan-2014 23:18:24 Wed 17 15 8 17 14 8 8 76
15/01/2014 23:19 15-Jan-2014 23:19:24 Wed 17 15 8 18 16 8 8 77
15/01/2014 23:20 15-Jan-2014 23:20:24 Wed 16 14 8 18 15 9 8 76
15/01/2014 23:21 15-Jan-2014 23:21:24 Wed 16 14 8 18 16 9 8 77
15/01/2014 23:22 15-Jan-2014 23:22:24 Wed 16 14 8 18 14 8 8 78
15/01/2014 23:23 15-Jan-2014 23:23:24 Wed 16 14 8 17 14 8 8 75
15/01/2014 23:24 15-Jan-2014 23:24:24 Wed 16 14 8 18 15 8 8 78
15/01/2014 23:25 15-Jan-2014 23:25:24 Wed 16 14 8 17 14 8 8 79
15/01/2014 23:26 15-Jan-2014 23:26:24 Wed 15 13 9 18 14 8 8 79
15/01/2014 23:27 15-Jan-2014 23:27:24 Wed 16 13 8 19 17 8 8 80
15/01/2014 23:28 15-Jan-2014 23:28:24 Wed 15 13 8 16 13 8 8 80
15/01/2014 23:29 15-Jan-2014 23:29:24 Wed 16 13 8 18 16 8 8 81
15/01/2014 23:30 15-Jan-2014 23:30:24 Wed 17 14 9 21 18 10 8 81
15/01/2014 23:31 15-Jan-2014 23:31:24 Wed 16 14 9 19 16 9 8 81
15/01/2014 23:32 15-Jan-2014 23:32:24 Wed 16 13 8 21 19 10 8 81
15/01/2014 23:33 15-Jan-2014 23:33:24 Wed 16 14 8 19 16 9 8 81
15/01/2014 23:34 15-Jan-2014 23:34:24 Wed 16 14 8 19 16 8 8 82
15/01/2014 23:35 15-Jan-2014 23:35:24 Wed 15 13 8 21 18 10 8 81
15/01/2014 23:36 15-Jan-2014 23:36:24 Wed 15 13 8 22 19 11 8 82
15/01/2014 23:37 15-Jan-2014 23:37:24 Wed 15 13 8 19 16 9 8 82
15/01/2014 23:38 15-Jan-2014 23:38:24 Wed 15 13 8 22 20 9 8 83
15/01/2014 23:39 15-Jan-2014 23:39:24 Wed 15 13 8 20 18 11 8 82
15/01/2014 23:40 15-Jan-2014 23:40:24 Wed 15 13 8 22 20 10 8 84
15/01/2014 23:41 15-Jan-2014 23:41:24 Wed 15 13 8 20 15 8 8 83
15/01/2014 23:42 15-Jan-2014 23:42:24 Wed 15 13 8 21 17 8 8 83
15/01/2014 23:43 15-Jan-2014 23:43:24 Wed 15 13 8 22 20 10 8 82
15/01/2014 23:44 15-Jan-2014 23:44:24 Wed 15 13 8 20 18 8 8 82
15/01/2014 23:45 15-Jan-2014 23:45:24 Wed 14 13 8 21 19 8 8 81
15/01/2014 23:46 15-Jan-2014 23:46:24 Wed 15 13 8 21 19 8 8 82
15/01/2014 23:47 15-Jan-2014 23:47:24 Wed 15 13 8 21 18 8 8 82
15/01/2014 23:48 15-Jan-2014 23:48:24 Wed 15 13 8 22 20 9 8 83
15/01/2014 23:49 15-Jan-2014 23:49:24 Wed 15 13 8 22 19 10 8 83
15/01/2014 23:50 15-Jan-2014 23:50:24 Wed 14 12 8 14 12 8 8 78
15/01/2014 23:51 15-Jan-2014 23:51:24 Wed 13 11 8 14 12 8 9 76
15/01/2014 23:52 15-Jan-2014 23:52:24 Wed 14 11 8 13 10 8 9 74
15/01/2014 23:53 15-Jan-2014 23:53:24 Wed 14 13 9 14 12 8 9 71
15/01/2014 23:54 15-Jan-2014 23:54:24 Wed 15 13 8 14 12 9 9 68
15/01/2014 23:55 15-Jan-2014 23:55:24 Wed 18 17 10 18 16 8 8 73
15/01/2014 23:56 15-Jan-2014 23:56:24 Wed 17 16 8 18 15 9 8 75
15/01/2014 23:57 15-Jan-2014 23:57:24 Wed 17 15 9 17 15 8 8 77
15/01/2014 23:58 15-Jan-2014 23:58:24 Wed 17 15 8 17 15 8 8 74
15/01/2014 23:59 15-Jan-2014 23:59:24 Wed 17 15 8 17 14 9 9 73
16/01/2014 00:00 16-Jan-2014 00:00:24 Thu 16 15 8 18 15 8 8 76
16/01/2014 00:01 16-Jan-2014 00:01:24 Thu 16 14 8 16 14 8 8 74
16/01/2014 00:02 16-Jan-2014 00:02:24 Thu 16 14 8 16 14 8 8 77
16/01/2014 00:03 16-Jan-2014 00:03:24 Thu 16 14 8 16 13 8 8 78
16/01/2014 00:04 16-Jan-2014 00:04:24 Thu 16 14 8 20 17 8 8 78
16/01/2014 00:05 16-Jan-2014 00:05:24 Thu 16 14 8 17 14 8 8 78
16/01/2014 00:06 16-Jan-2014 00:06:24 Thu 15 13 8 19 15 8 8 79
16/01/2014 00:07 16-Jan-2014 00:07:24 Thu 15 13 8 19 16 8 8 80
16/01/2014 00:08 16-Jan-2014 00:08:24 Thu 15 14 9 19 16 8 8 79
16/01/2014 00:09 16-Jan-2014 00:09:24 Thu 15 13 8 15 13 8 8 79
16/01/2014 00:10 16-Jan-2014 00:10:24 Thu 15 13 8 15 13 8 8 79
16/01/2014 00:11 16-Jan-2014 00:11:24 Thu 15 13 8 20 18 10 8 80
16/01/2014 00:12 16-Jan-2014 00:12:24 Thu 15 13 8 14 12 8 8 78
16/01/2014 00:13 16-Jan-2014 00:13:24 Thu 15 13 8 20 17 8 8 81
16/01/2014 00:14 16-Jan-2014 00:14:24 Thu 14 13 8 20 17 8 8 80
16/01/2014 00:15 16-Jan-2014 00:15:24 Thu 15 13 8 15 13 8 8 77
16/01/2014 00:16 16-Jan-2014 00:16:24 Thu 15 14 8 17 14 8 8 79
16/01/2014 00:17 16-Jan-2014 00:17:24 Thu 15 14 8 15 14 9 8 78
16/01/2014 00:18 16-Jan-2014 00:18:24 Thu 15 14 9 18 15 9 8 78
16/01/2014 00:19 16-Jan-2014 00:19:24 Thu 15 14 8 15 14 9 8 78
16/01/2014 00:20 16-Jan-2014 00:20:24 Thu 15 14 10 15 14 8 8 78
16/01/2014 00:21 16-Jan-2014 00:21:24 Thu 15 14 8 16 14 10 8 78
16/01/2014 00:22 16-Jan-2014 00:22:24 Thu 15 14 8 15 14 8 9 75
16/01/2014 00:23 16-Jan-2014 00:23:24 Thu 15 13 8 15 13 9 9 75
16/01/2014 01:09 16-Jan-2014 01:09:14 Thu 12 38
16/01/2014 01:10 16-Jan-2014 01:10:14 Thu 19 18 12 19 17 12 14 55
16/01/2014 01:11 16-Jan-2014 01:11:14 Thu 18 17 8 18 16 9 12 59
16/01/2014 01:12 16-Jan-2014 01:12:14 Thu 18 16 9 17 15 9 11 63
16/01/2014 01:13 16-Jan-2014 01:13:14 Thu 18 16 9 18 15 8 11 60
16/01/2014 01:14 16-Jan-2014 01:14:14 Thu 23 17 8 17 14 8 11 60
16/01/2014 01:15 16-Jan-2014 01:15:14 Thu 23 17 8 16 13 8 12 61
16/01/2014 01:16 16-Jan-2014 01:16:14 Thu 23 16 8 17 13 8 11 63
16/01/2014 01:17 16-Jan-2014 01:17:14 Thu 19 14 8 15 13 8 11 64
16/01/2014 01:18 16-Jan-2014 01:18:14 Thu 18 15 8 17 13 8 10 69
16/01/2014 01:19 16-Jan-2014 01:19:14 Thu 16 14 8 18 14 9 9 69
16/01/2014 01:20 16-Jan-2014 01:20:14 Thu 17 15 9 18 14 9 9 70
16/01/2014 01:21 16-Jan-2014 01:21:14 Thu 16 15 8 17 14 9 9 68
16/01/2014 01:22 16-Jan-2014 01:22:14 Thu 17 15 9 17 14 8 9 70
16/01/2014 01:23 16-Jan-2014 01:23:14 Thu 16 14 8 17 14 8 9 71
16/01/2014 01:24 16-Jan-2014 01:24:14 Thu 16 14 8 17 14 9 9 71
16/01/2014 01:25 16-Jan-2014 01:25:14 Thu 16 14 8 17 13 8 9 71
16/01/2014 01:26 16-Jan-2014 01:26:14 Thu 15 14 8 17 13 9 9 72
16/01/2014 01:27 16-Jan-2014 01:27:14 Thu 15 13 8 19 17 10 8 75
16/01/2014 01:28 16-Jan-2014 01:28:14 Thu 15 13 8 20 16 8 9 74
16/01/2014 01:29 16-Jan-2014 01:29:14 Thu 15 13 8 18 13 8 8 74
16/01/2014 01:30 16-Jan-2014 01:30:14 Thu 15 13 8 17 13 8 9 74
16/01/2014 01:31 16-Jan-2014 01:31:14 Thu 14 12 8 16 12 8 9 75
16/01/2014 01:32 16-Jan-2014 01:32:14 Thu 15 13 8 18 13 8 8 75
16/01/2014 01:33 16-Jan-2014 01:33:14 Thu 15 13 8 19 17 12 8 78
16/01/2014 01:34 16-Jan-2014 01:34:14 Thu 15 13 8 21 18 11 8 78
16/01/2014 01:35 16-Jan-2014 01:35:14 Thu 15 13 8 21 18 9 8 79
16/01/2014 01:36 16-Jan-2014 01:36:14 Thu 15 13 8 15 13 8 8 78
16/01/2014 01:37 16-Jan-2014 01:37:14 Thu 15 13 8 21 19 8 8 78
16/01/2014 01:38 16-Jan-2014 01:38:14 Thu 15 13 8 20 18 9 8 78
16/01/2014 01:39 16-Jan-2014 01:39:14 Thu 15 13 8 19 15 9 8 78
16/01/2014 01:40 16-Jan-2014 01:40:14 Thu 15 13 8 20 17 8 8 78
16/01/2014 01:41 16-Jan-2014 01:41:14 Thu 14 13 9 18 14 8 8 78
16/01/2014 01:42 16-Jan-2014 01:42:14 Thu 15 13 8 21 19 10 8 80
16/01/2014 01:43 16-Jan-2014 01:43:14 Thu 15 13 8 20 18 9 8 81
16/01/2014 01:44 16-Jan-2014 01:44:14 Thu 14 13 8 20 18 9 8 79
16/01/2014 01:45 16-Jan-2014 01:45:14 Thu 15 13 8 21 18 8 8 79
16/01/2014 01:46 16-Jan-2014 01:46:14 Thu 14 12 8 20 17 8 8 79
16/01/2014 01:47 16-Jan-2014 01:47:14 Thu 14 13 8 21 19 10 8 78
16/01/2014 01:48 16-Jan-2014 01:48:14 Thu 14 12 8 14 12 8 8 77
16/01/2014 01:49 16-Jan-2014 01:49:14 Thu 14 12 8 21 17 8 8 78
16/01/2014 01:50 16-Jan-2014 01:50:14 Thu 14 12 8 20 18 9 8 80
16/01/2014 01:51 16-Jan-2014 01:51:14 Thu 14 12 8 19 15 8 8 79
16/01/2014 01:52 16-Jan-2014 01:52:14 Thu 14 13 8 21 18 9 8 81
16/01/2014 01:53 16-Jan-2014 01:53:14 Thu 14 12 8 17 14 8 8 78
16/01/2014 01:54 16-Jan-2014 01:54:14 Thu 14 12 8 18 16 9 8 80
16/01/2014 01:55 16-Jan-2014 01:55:14 Thu 14 12 8 14 12 8 8 78
16/01/2014 01:56 16-Jan-2014 01:56:14 Thu 14 12 8 17 13 8 8 79
16/01/2014 01:57 16-Jan-2014 01:57:14 Thu 14 12 8 19 15 8 8 81
16/01/2014 01:58 16-Jan-2014 01:58:14 Thu 14 13 8 17 15 8 8 79
16/01/2014 01:59 16-Jan-2014 01:59:14 Thu 14 12 8 15 13 8 8 79
16/01/2014 02:00 16-Jan-2014 02:00:14 Thu 14 13 8 18 15 8 8 78
16/01/2014 02:01 16-Jan-2014 02:01:14 Thu 14 12 8 14 12 8 8 78
16/01/2014 02:02 16-Jan-2014 02:02:14 Thu 14 13 8 17 14 9 8 79
16/01/2014 02:03 16-Jan-2014 02:03:14 Thu 14 12 8 15 13 8 8 78
16/01/2014 02:04 16-Jan-2014 02:04:14 Thu 14 12 8 14 12 8 8 78
16/01/2014 02:05 16-Jan-2014 02:05:14 Thu 14 12 8 14 10 8 9 74
16/01/2014 02:06 16-Jan-2014 02:06:14 Thu 13 11 8 14 11 8 9 72
16/01/2014 02:07 16-Jan-2014 02:07:14 Thu 12 11 8 13 10 8 9 70
16/01/2014 02:08 16-Jan-2014 02:08:14 Thu 12 10 8 13 10 8 9 68
16/01/2014 02:09 16-Jan-2014 02:09:14 Thu 13 11 8 12 9 8 9 66
16/01/2014 02:10 16-Jan-2014 02:10:14 Thu 12 10 8 12 11 8 9 64
16/01/2014 02:11 16-Jan-2014 02:11:14 Thu 12 10 8 12 10 8 9 63
16/01/2014 02:12 16-Jan-2014 02:12:14 Thu 13 12 8 13 11 8 9 61
16/01/2014 02:13 16-Jan-2014 02:13:14 Thu 13 11 8 13 10 8 9 59
16/01/2014 02:14 16-Jan-2014 02:14:14 Thu 13 12 8 14 11 8 8 57
16/01/2014 02:15 16-Jan-2014 02:15:14 Thu 14 12 8 13 11 8 8 56
16/01/2014 02:16 16-Jan-2014 02:16:14 Thu 14 12 8 14 11 9 8 55
16/01/2014 02:17 16-Jan-2014 02:17:14 Thu 14 12 9 14 11 10 8 54
16/01/2014 02:18 16-Jan-2014 02:18:14 Thu 19 17 11 19 16 10 10 57
16/01/2014 02:19 16-Jan-2014 02:19:14 Thu 17 16 9 18 15 8 9 62
16/01/2014 02:20 16-Jan-2014 02:20:14 Thu 17 16 8 18 15 9 9 64
16/01/2014 02:21 16-Jan-2014 02:21:14 Thu 17 15 8 17 15 8 9 66
16/01/2014 02:22 16-Jan-2014 02:22:14 Thu 17 15 8 17 14 8 9 67
16/01/2014 02:23 16-Jan-2014 02:23:14 Thu 17 15 9 19 14 9 9 68
16/01/2014 02:24 16-Jan-2014 02:24:14 Thu 17 15 8 18 14 8 8 71
16/01/2014 02:25 16-Jan-2014 02:25:14 Thu 17 15 8 19 15 8 8 72
16/01/2014 02:26 16-Jan-2014 02:26:14 Thu 16 14 8 18 14 8 8 74
16/01/2014 02:27 16-Jan-2014 02:27:14 Thu 16 14 8 17 14 8 8 73
16/01/2014 02:28 16-Jan-2014 02:28:14 Thu 16 14 8 17 14 9 8 72
16/01/2014 02:29 16-Jan-2014 02:29:14 Thu 16 13 8 18 15 8 8 75
16/01/2014 02:30 16-Jan-2014 02:30:14 Thu 15 13 8 20 16 9 8 76
16/01/2014 02:31 16-Jan-2014 02:31:14 Thu 15 13 8 18 15 10 8 76
16/01/2014 02:32 16-Jan-2014 02:32:14 Thu 15 13 8 16 13 8 8 77
16/01/2014 02:33 16-Jan-2014 02:33:14 Thu 15 13 8 19 16 8 8 77
16/01/2014 02:34 16-Jan-2014 02:34:14 Thu 15 12 8 18 14 8 8 76
16/01/2014 02:35 16-Jan-2014 02:35:14 Thu 14 13 8 14 12 8 8 76
16/01/2014 02:36 16-Jan-2014 02:36:14 Thu 15 14 8 15 13 9 8 76
16/01/2014 02:37 16-Jan-2014 02:37:14 Thu 15 13 8 15 13 8 8 75
16/01/2014 02:38 16-Jan-2014 02:38:14 Thu 15 13 8 15 13 8 8 76
16/01/2014 02:39 16-Jan-2014 02:39:14 Thu 15 13 8 15 13 8 8 75
16/01/2014 02:40 16-Jan-2014 02:40:14 Thu 15 13 9 16 13 8 8 75
16/01/2014 02:41 16-Jan-2014 02:41:14 Thu 15 13 8 15 13 8 8 74
16/01/2014 02:42 16-Jan-2014 02:42:14 Thu 15 14 9 15 13 8 8 77
16/01/2014 02:43 16-Jan-2014 02:43:14 Thu 15 13 8 15 13 8 8 76
16/01/2014 02:44 16-Jan-2014 02:44:14 Thu 15 13 9 15 13 8 8 75
16/01/2014 02:45 16-Jan-2014 02:45:14 Thu 15 13 8 15 13 9 8 76
16/01/2014 02:46 16-Jan-2014 02:46:14 Thu 14 13 8 14 12 8 8 76
16/01/2014 02:47 16-Jan-2014 02:47:14 Thu 14 13 8 14 13 9 8 77
16/01/2014 02:48 16-Jan-2014 02:48:14 Thu 14 13 8 14 12 8 8 76
16/01/2014 02:49 16-Jan-2014 02:49:14 Thu 14 12 8 14 12 8 8 77
16/01/2014 02:50 16-Jan-2014 02:50:14 Thu 14 13 8 14 13 8 8 74
16/01/2014 02:51 16-Jan-2014 02:51:14 Thu 15 13 8 15 13 8 9 74
16/01/2014 02:52 16-Jan-2014 02:52:14 Thu 15 14 8 15 13 8 8 75
16/01/2014 02:53 16-Jan-2014 02:53:14 Thu 15 13 8 14 12 8 8 75
16/01/2014 02:54 16-Jan-2014 02:54:14 Thu 14 13 8 14 13 8 9 72
16/01/2014 02:55 16-Jan-2014 02:55:14 Thu 16 14 10 15 14 9 9 69
16/01/2014 02:56 16-Jan-2014 02:56:14 Thu 16 15 11 16 14 11 9 67
16/01/2014 02:57 16-Jan-2014 02:57:14 Thu 16 15 11 16 15 10 9 65
16/01/2014 02:58 16-Jan-2014 02:58:14 Thu 17 15 10 16 15 11 9 63
16/01/2014 02:59 16-Jan-2014 02:59:14 Thu 17 16 11 17 15 10 9 60
16/01/2014 03:00 16-Jan-2014 03:00:14 Thu 17 15 10 17 15 10 8 58
16/01/2014 03:01 16-Jan-2014 03:01:14 Thu 16 15 10 16 15 10 8 56
16/01/2014 03:02 16-Jan-2014 03:02:14 Thu 16 15 10 16 15 10 8 55
16/01/2014 03:03 16-Jan-2014 03:03:14 Thu 16 15 10 17 15 10 8 54
16/01/2014 03:04 16-Jan-2014 03:04:14 Thu 16 15 9 17 15 10 8 53
16/01/2014 03:05 16-Jan-2014 03:05:14 Thu 16 15 9 16 14 10 8 51
16/01/2014 03:06 16-Jan-2014 03:06:14 Thu 16 15 10 16 14 8 8 51
16/01/2014 03:07 16-Jan-2014 03:07:14 Thu 16 15 10 16 14 9 8 50
16/01/2014 03:08 16-Jan-2014 03:08:14 Thu 16 15 10 16 14 9 8 50
16/01/2014 03:09 16-Jan-2014 03:09:14 Thu 16 15 9 16 13 9 8 49
16/01/2014 03:10 16-Jan-2014 03:10:14 Thu 16 15 8 16 14 8 9 49
16/01/2014 03:11 16-Jan-2014 03:11:14 Thu 16 14 9 16 13 8 9 47
16/01/2014 03:12 16-Jan-2014 03:12:14 Thu 16 15 8 15 12 8 9 45
16/01/2014 03:13 16-Jan-2014 03:13:14 Thu 16 14 10 16 13 8 9 44
16/01/2014 03:14 16-Jan-2014 03:14:14 Thu 16 14 8 16 13 8 9 42
16/01/2014 03:15 16-Jan-2014 03:15:14 Thu 15 14 8 15 13 8 9 41
16/01/2014 03:16 16-Jan-2014 03:16:14 Thu 15 14 8 9 41
16/01/2014 03:17 16-Jan-2014 03:17:14 Thu 16 14 8 9 40
16/01/2014 03:18 16-Jan-2014 03:18:14 Thu 15 14 8 9 39
16/01/2014 03:19 16-Jan-2014 03:19:14 Thu 15 14 8 9 39
16/01/2014 03:20 16-Jan-2014 03:20:14 Thu 15 13 8 9 38
16/01/2014 03:21 16-Jan-2014 03:21:14 Thu 15 14 8 9 38
16/01/2014 03:22 16-Jan-2014 03:22:14 Thu 15 14 8 9 37
16/01/2014 03:23 16-Jan-2014 03:23:14 Thu 18 17 10 15 13 8 9 36
16/01/2014 03:24 16-Jan-2014 03:24:14 Thu 19 17 10 18 17 11 10 40
16/01/2014 03:25 16-Jan-2014 03:25:14 Thu 18 16 9 18 16 8 11 45
16/01/2014 03:26 16-Jan-2014 03:26:14 Thu 17 16 9 17 15 8 11 50
16/01/2014 03:27 16-Jan-2014 03:27:14 Thu 18 16 8 17 15 8 12 47
16/01/2014 03:28 16-Jan-2014 03:28:14 Thu 23 17 8 16 14 8 13 49
16/01/2014 03:29 16-Jan-2014 03:29:14 Thu 18 15 8 16 13 8 13 51
16/01/2014 03:30 16-Jan-2014 03:30:14 Thu 18 14 8 16 13 8 12 53
16/01/2014 03:31 16-Jan-2014 03:31:14 Thu 20 14 8 17 12 8 12 56
16/01/2014 03:32 16-Jan-2014 03:32:14 Thu 22 15 8 17 13 8 10 62
16/01/2014 03:33 16-Jan-2014 03:33:14 Thu 22 15 8 18 13 8 10 64
16/01/2014 03:34 16-Jan-2014 03:34:14 Thu 16 15 8 16 14 8 10 62
16/01/2014 03:35 16-Jan-2014 03:35:14 Thu 16 14 8 15 14 9 11 58
16/01/2014 03:36 16-Jan-2014 03:36:14 Thu 16 14 8 16 13 8 12 56
16/01/2014 03:37 16-Jan-2014 03:37:14 Thu 15 13 8 15 12 8 12 54
16/01/2014 03:38 16-Jan-2014 03:38:14 Thu 15 13 8 15 12 8 12 53
16/01/2014 03:39 16-Jan-2014 03:39:14 Thu 15 13 8 15 12 8 11 54
16/01/2014 03:40 16-Jan-2014 03:40:14 Thu 18 16 9 18 16 9 10 57
16/01/2014 03:41 16-Jan-2014 03:41:14 Thu 18 16 8 18 15 8 10 60
16/01/2014 03:42 16-Jan-2014 03:42:14 Thu 0 0 0 18 15 8 9 63
16/01/2014 03:43 16-Jan-2014 03:43:14 Thu 0 0 0 18 15 8 9 63
16/01/2014 03:44 16-Jan-2014 03:44:14 Thu 0 0 0 18 14 8 9 64
16/01/2014 03:45 16-Jan-2014 03:45:14 Thu 0 0 0 18 14 8 9 65
16/01/2014 03:46 16-Jan-2014 03:46:14 Thu 0 0 0 18 14 8 9 67
16/01/2014 03:47 16-Jan-2014 03:47:14 Thu 0 0 0 18 14 8 9 67
16/01/2014 03:48 16-Jan-2014 03:48:14 Thu 0 0 0 17 13 8 9 68
16/01/2014 03:49 16-Jan-2014 03:49:14 Thu 18 15 8 17 13 8 9 69
16/01/2014 03:50 16-Jan-2014 03:50:14 Thu 17 14 8 18 13 8 8 70
16/01/2014 03:51 16-Jan-2014 03:51:14 Thu 16 14 8 17 13 8 8 71
16/01/2014 03:52 16-Jan-2014 03:52:14 Thu 16 14 8 19 14 8 8 71
16/01/2014 03:53 16-Jan-2014 03:53:14 Thu 16 14 8 18 14 8 8 72
16/01/2014 03:54 16-Jan-2014 03:54:14 Thu 16 14 8 18 14 8 8 74
16/01/2014 03:55 16-Jan-2014 03:55:14 Thu 16 13 8 19 15 8 8 76
16/01/2014 03:56 16-Jan-2014 03:56:14 Thu 16 13 8 18 14 8 8 75
16/01/2014 03:57 16-Jan-2014 03:57:14 Thu 16 14 8 18 15 8 8 76
16/01/2014 03:58 16-Jan-2014 03:58:14 Thu 15 13 8 16 13 8 8 76
16/01/2014 03:59 16-Jan-2014 03:59:14 Thu 15 13 8 17 13 8 8 76
16/01/2014 04:00 16-Jan-2014 04:00:14 Thu 15 13 8 17 12 8 8 77
16/01/2014 04:01 16-Jan-2014 04:01:14 Thu 14 12 8 19 17 8 8 75
16/01/2014 04:02 16-Jan-2014 04:02:14 Thu 14 13 8 20 17 8 8 76
16/01/2014 04:03 16-Jan-2014 04:03:14 Thu 14 12 8 14 12 8 8 76
16/01/2014 04:04 16-Jan-2014 04:04:14 Thu 14 13 8 15 12 8 8 75
16/01/2014 04:05 16-Jan-2014 04:05:14 Thu 14 12 8 14 12 8 8 75
16/01/2014 04:06 16-Jan-2014 04:06:14 Thu 14 12 8 14 12 8 8 75
16/01/2014 04:07 16-Jan-2014 04:07:14 Thu 14 12 8 14 12 8 8 75
16/01/2014 04:08 16-Jan-2014 04:08:14 Thu 14 13 8 14 12 8 8 76
16/01/2014 04:09 16-Jan-2014 04:09:14 Thu 14 13 8 18 16 9 8 78
16/01/2014 04:10 16-Jan-2014 04:10:14 Thu 14 12 8 16 12 8 8 77
16/01/2014 04:11 16-Jan-2014 04:11:14 Thu 15 13 9 18 15 8 8 78
16/01/2014 04:12 16-Jan-2014 04:12:14 Thu 14 13 8 19 16 8 8 78
16/01/2014 04:13 16-Jan-2014 04:13:14 Thu 14 12 8 15 13 8 8 77
16/01/2014 04:14 16-Jan-2014 04:14:14 Thu 14 13 8 18 14 8 8 78
16/01/2014 04:15 16-Jan-2014 04:15:14 Thu 14 12 8 17 15 8 8 78
16/01/2014 04:16 16-Jan-2014 04:16:14 Thu 14 12 8 19 17 8 8 79
16/01/2014 04:17 16-Jan-2014 04:17:14 Thu 14 12 8 14 12 8 8 78
16/01/2014 04:18 16-Jan-2014 04:18:14 Thu 14 12 8 20 18 10 8 80
16/01/2014 04:19 16-Jan-2014 04:19:14 Thu 14 13 8 18 16 8 7 80
16/01/2014 04:20 16-Jan-2014 04:20:14 Thu 14 13 8 18 16 10 8 79
16/01/2014 04:21 16-Jan-2014 04:21:14 Thu 14 12 8 21 19 9 8 80
16/01/2014 04:22 16-Jan-2014 04:22:14 Thu 14 13 9 19 16 9 8 79
16/01/2014 04:23 16-Jan-2014 04:23:14 Thu 15 13 9 14 13 9 8 78
16/01/2014 04:24 16-Jan-2014 04:24:14 Thu 14 13 8 16 12 8 8 79
16/01/2014 04:25 16-Jan-2014 04:25:14 Thu 14 13 8 15 13 8 8 77
16/01/2014 04:26 16-Jan-2014 04:26:14 Thu 14 12 8 15 13 8 8 77
16/01/2014 04:27 16-Jan-2014 04:27:14 Thu 14 12 8 18 14 8 8 79
16/01/2014 04:28 16-Jan-2014 04:28:14 Thu 14 12 8 18 15 8 8 79
16/01/2014 04:29 16-Jan-2014 04:29:14 Thu 14 12 8 18 13 8 8 79
16/01/2014 04:30 16-Jan-2014 04:30:14 Thu 13 12 8 18 16 9 8 78
16/01/2014 04:31 16-Jan-2014 04:31:14 Thu 13 12 8 14 12 8 8 74
16/01/2014 04:32 16-Jan-2014 04:32:14 Thu 13 11 8 13 11 8 8 72
16/01/2014 04:33 16-Jan-2014 04:33:14 Thu 14 12 8 13 11 8 8 69
16/01/2014 04:34 16-Jan-2014 04:34:14 Thu 14 12 8 14 11 8 8 67
16/01/2014 04:35 16-Jan-2014 04:35:14 Thu 14 12 8 14 12 8 8 65
16/01/2014 04:36 16-Jan-2014 04:36:14 Thu 19 17 10 19 16 8 8 69
16/01/2014 04:37 16-Jan-2014 04:37:14 Thu 18 16 9 18 16 9 8 71
16/01/2014 04:38 16-Jan-2014 04:38:14 Thu 17 15 8 17 15 8 8 72
16/01/2014 04:39 16-Jan-2014 04:39:14 Thu 17 15 9 17 15 8 8 74
16/01/2014 04:40 16-Jan-2014 04:40:14 Thu 16 15 8 17 15 8 8 75
16/01/2014 04:41 16-Jan-2014 04:41:14 Thu 16 14 8 16 14 8 8 75
16/01/2014 04:42 16-Jan-2014 04:42:14 Thu 16 14 8 21 18 8 8 77
16/01/2014 04:43 16-Jan-2014 04:43:14 Thu 16 14 8 17 13 8 8 77
16/01/2014 04:44 16-Jan-2014 04:44:14 Thu 15 13 8 15 13 8 8 76
16/01/2014 04:45 16-Jan-2014 04:45:14 Thu 16 13 8 16 13 8 8 76
16/01/2014 04:46 16-Jan-2014 04:46:14 Thu 15 13 8 15 13 8 8 76
16/01/2014 04:47 16-Jan-2014 04:47:14 Thu 15 13 8 20 17 9 8 77
16/01/2014 04:48 16-Jan-2014 04:48:14 Thu 15 14 8 17 14 9 8 77
16/01/2014 04:49 16-Jan-2014 04:49:14 Thu 15 13 8 19 16 9 8 76
16/01/2014 04:50 16-Jan-2014 04:50:14 Thu 15 13 8 17 14 8 8 75
16/01/2014 04:51 16-Jan-2014 04:51:14 Thu 15 13 8 15 13 8 9 71
16/01/2014 04:52 16-Jan-2014 04:52:14 Thu 18 17 9 18 17 10 8 74
16/01/2014 04:53 16-Jan-2014 04:53:14 Thu 17 16 8 18 16 8 8 73
16/01/2014 04:54 16-Jan-2014 04:54:14 Thu 17 15 8 17 15 8 8 75
16/01/2014 04:55 16-Jan-2014 04:55:14 Thu 16 15 9 17 14 8 8 76
16/01/2014 04:56 16-Jan-2014 04:56:14 Thu 16 14 8 16 14 8 8 76
16/01/2014 04:57 16-Jan-2014 04:57:14 Thu 16 14 8 16 13 8 8 75
16/01/2014 04:58 16-Jan-2014 04:58:14 Thu 15 14 8 16 13 8 8 73
16/01/2014 04:59 16-Jan-2014 04:59:14 Thu 15 13 8 15 13 8 8 74
16/01/2014 05:28 16-Jan-2014 05:28:25 Thu 11 55
16/01/2014 05:29 16-Jan-2014 05:29:25 Thu 19 18 11 19 17 11 11 58
16/01/2014 05:30 16-Jan-2014 05:30:25 Thu 18 17 9 19 17 8 11 56
16/01/2014 05:31 16-Jan-2014 05:31:25 Thu 18 17 10 19 16 9 11 56
16/01/2014 05:32 16-Jan-2014 05:32:25 Thu 18 17 10 19 16 9 11 54
16/01/2014 05:33 16-Jan-2014 05:33:25 Thu 18 17 10 19 16 9 10 53
16/01/2014 05:34 16-Jan-2014 05:34:25 Thu 18 17 10 19 17 10 10 52
16/01/2014 05:35 16-Jan-2014 05:35:25 Thu 19 18 11 19 17 11 10 55
16/01/2014 05:36 16-Jan-2014 05:36:25 Thu 18 17 9 18 16 9 10 53
16/01/2014 05:37 16-Jan-2014 05:37:25 Thu 18 16 8 18 16 8 10 60
16/01/2014 05:38 16-Jan-2014 05:38:25 Thu 17 16 8 17 15 10 10 58
16/01/2014 05:39 16-Jan-2014 05:39:25 Thu 18 15 8 17 15 8 10 58
16/01/2014 05:40 16-Jan-2014 05:40:25 Thu 20 16 8 16 14 8 10 59
16/01/2014 05:41 16-Jan-2014 05:41:25 Thu 20 15 8 16 13 8 10 63
16/01/2014 05:42 16-Jan-2014 05:42:25 Thu 20 15 8 16 13 8 10 63
16/01/2014 05:43 16-Jan-2014 05:43:25 Thu 17 14 8 16 13 8 9 67
16/01/2014 05:44 16-Jan-2014 05:44:25 Thu 16 14 8 19 13 8 9 71
16/01/2014 05:45 16-Jan-2014 05:45:25 Thu 17 15 8 17 14 8 9 67
16/01/2014 05:46 16-Jan-2014 05:46:25 Thu 17 15 8 17 14 9 9 68
16/01/2014 05:47 16-Jan-2014 05:47:25 Thu 16 14 8 16 14 9 9 68
16/01/2014 05:48 16-Jan-2014 05:48:25 Thu 16 15 8 17 14 8 9 68
16/01/2014 05:49 16-Jan-2014 05:49:25 Thu 16 14 8 18 14 9 8 70
16/01/2014 05:50 16-Jan-2014 05:50:25 Thu 16 14 8 19 14 8 8 70
16/01/2014 05:51 16-Jan-2014 05:51:25 Thu 16 14 9 18 14 9 8 70
16/01/2014 05:52 16-Jan-2014 05:52:25 Thu 15 14 8 16 13 8 9 69
16/01/2014 05:53 16-Jan-2014 05:53:25 Thu 15 14 8 17 13 9 9 68
16/01/2014 05:54 16-Jan-2014 05:54:25 Thu 15 13 8 18 13 8 9 68
16/01/2014 05:55 16-Jan-2014 05:55:25 Thu 15 13 9 17 13 8 9 68
16/01/2014 05:56 16-Jan-2014 05:56:25 Thu 15 14 8 15 13 8 8 68
16/01/2014 05:57 16-Jan-2014 05:57:25 Thu 15 13 8 18 13 8 9 68
16/01/2014 05:58 16-Jan-2014 05:58:25 Thu 15 13 8 17 13 8 9 68
16/01/2014 05:59 16-Jan-2014 05:59:25 Thu 14 13 8 14 12 8 9 67
16/01/2014 06:00 16-Jan-2014 06:00:25 Thu 15 13 9 14 13 9 9 67
16/01/2014 06:01 16-Jan-2014 06:01:25 Thu 15 13 8 18 13 8 9 69
16/01/2014 06:02 16-Jan-2014 06:02:25 Thu 15 13 8 16 12 8 8 70
16/01/2014 06:03 16-Jan-2014 06:03:25 Thu 15 13 8 15 12 8 8 71
16/01/2014 06:04 16-Jan-2014 06:04:25 Thu 15 13 8 17 13 8 8 71
16/01/2014 06:05 16-Jan-2014 06:05:25 Thu 15 14 8 16 13 8 8 72
16/01/2014 06:06 16-Jan-2014 06:06:25 Thu 15 13 8 18 13 8 8 73
16/01/2014 06:07 16-Jan-2014 06:07:25 Thu 15 13 8 15 13 8 8 72
16/01/2014 06:08 16-Jan-2014 06:08:25 Thu 15 14 9 15 13 9 8 70
16/01/2014 06:09 16-Jan-2014 06:09:25 Thu 15 13 8 15 13 8 9 67
16/01/2014 06:10 16-Jan-2014 06:10:25 Thu 18 17 8 18 16 8 9 66
16/01/2014 06:11 16-Jan-2014 06:11:25 Thu 18 16 9 18 16 9 9 64
16/01/2014 06:12 16-Jan-2014 06:12:25 Thu 17 15 8 18 15 8 9 63
16/01/2014 06:13 16-Jan-2014 06:13:25 Thu 17 15 8 18 15 8 9 61
16/01/2014 06:14 16-Jan-2014 06:14:25 Thu 17 15 8 17 15 8 9 59
16/01/2014 06:15 16-Jan-2014 06:15:25 Thu 17 15 8 18 15 9 9 57
16/01/2014 06:16 16-Jan-2014 06:16:25 Thu 17 15 8 17 14 9 9 56
16/01/2014 06:17 16-Jan-2014 06:17:25 Thu 19 18 10 19 17 10 9 58
16/01/2014 06:18 16-Jan-2014 06:18:25 Thu 18 17 10 18 16 10 9 61
16/01/2014 06:19 16-Jan-2014 06:19:25 Thu 18 16 8 17 15 9 9 60
16/01/2014 06:20 16-Jan-2014 06:20:25 Thu 17 15 8 18 15 8 9 61
16/01/2014 06:21 16-Jan-2014 06:21:25 Thu 17 15 8 18 15 8 9 63
16/01/2014 06:22 16-Jan-2014 06:22:25 Thu 17 15 8 18 15 8 9 64
16/01/2014 06:23 16-Jan-2014 06:23:25 Thu 17 15 9 16 14 8 9 62
16/01/2014 06:24 16-Jan-2014 06:24:25 Thu 16 15 8 18 14 8 9 64
16/01/2014 06:25 16-Jan-2014 06:25:25 Thu 16 15 8 16 13 8 9 64
16/01/2014 06:26 16-Jan-2014 06:26:25 Thu 16 14 8 19 14 9 9 65
16/01/2014 06:27 16-Jan-2014 06:27:25 Thu 16 14 8 16 13 8 9 65
16/01/2014 06:28 16-Jan-2014 06:28:25 Thu 16 14 8 16 13 8 9 64
16/01/2014 06:29 16-Jan-2014 06:29:25 Thu 16 14 8 16 13 8 9 65
16/01/2014 06:30 16-Jan-2014 06:30:25 Thu 16 14 8 16 13 8 8 68
16/01/2014 06:31 16-Jan-2014 06:31:25 Thu 16 14 8 15 13 8 8 68
16/01/2014 06:32 16-Jan-2014 06:32:25 Thu 16 14 8 15 12 8 9 67
16/01/2014 06:33 16-Jan-2014 06:33:25 Thu 15 13 8 15 12 8 9 69
16/01/2014 06:34 16-Jan-2014 06:34:25 Thu 15 13 8 15 12 8 9 70
16/01/2014 06:35 16-Jan-2014 06:35:25 Thu 15 12 8 16 12 8 9 71
16/01/2014 06:36 16-Jan-2014 06:36:25 Thu 15 13 8 14 12 8 9 71
16/01/2014 06:37 16-Jan-2014 06:37:25 Thu 14 12 8 14 11 8 10 67
16/01/2014 06:38 16-Jan-2014 06:38:25 Thu 15 13 9 14 13 8 9 67
16/01/2014 06:39 16-Jan-2014 06:39:25 Thu 14 13 8 14 13 8 9 66
16/01/2014 06:40 16-Jan-2014 06:40:25 Thu 14 13 8 14 12 8 9 63
16/01/2014 06:41 16-Jan-2014 06:41:25 Thu 14 13 9 14 12 8 10 62
16/01/2014 06:42 16-Jan-2014 06:42:25 Thu 14 13 8 15 13 8 9 64
16/01/2014 06:43 16-Jan-2014 06:43:25 Thu 14 13 8 14 12 8 9 66
16/01/2014 06:44 16-Jan-2014 06:44:25 Thu 14 12 8 14 12 8 10 62
16/01/2014 07:15 16-Jan-2014 07:15:11 Thu 13 48
16/01/2014 07:16 16-Jan-2014 07:16:11 Thu 17 16 13 14 43
16/01/2014 07:17 16-Jan-2014 07:17:11 Thu 17 16 12 17 16 12 13 44
16/01/2014 07:18 16-Jan-2014 07:18:11 Thu 17 16 11 17 15 10 12 43
16/01/2014 07:19 16-Jan-2014 07:19:11 Thu 19 18 11 19 17 12 12 42
16/01/2014 07:20 16-Jan-2014 07:20:11 Thu 18 17 10 19 16 9 12 42
16/01/2014 07:21 16-Jan-2014 07:21:11 Thu 18 16 11 18 16 12 12 42
16/01/2014 07:22 16-Jan-2014 07:22:11 Thu 17 16 11 17 15 11 11 44
16/01/2014 07:23 16-Jan-2014 07:23:11 Thu 17 16 10 17 15 11 11 43
16/01/2014 07:24 16-Jan-2014 07:24:11 Thu 17 15 10 12 42
16/01/2014 07:25 16-Jan-2014 07:25:11 Thu 16 15 9 16 14 8 11 46
16/01/2014 07:26 16-Jan-2014 07:26:11 Thu 16 15 9 16 14 8 10 51
16/01/2014 07:27 16-Jan-2014 07:27:11 Thu 16 14 9 16 14 8 10 52
16/01/2014 07:28 16-Jan-2014 07:28:11 Thu 16 14 8 16 13 9 10 56
16/01/2014 07:29 16-Jan-2014 07:29:11 Thu 16 14 8 16 13 9 10 52
16/01/2014 07:30 16-Jan-2014 07:30:11 Thu 16 14 8 16 13 8 11 55
16/01/2014 07:31 16-Jan-2014 07:31:11 Thu 16 14 8 17 12 8 11 57
16/01/2014 07:32 16-Jan-2014 07:32:11 Thu 20 14 8 15 13 8 11 58
16/01/2014 07:33 16-Jan-2014 07:33:11 Thu 23 15 8 16 12 8 10 63
16/01/2014 07:34 16-Jan-2014 07:34:11 Thu 24 16 8 14 12 8 10 61
16/01/2014 07:35 16-Jan-2014 07:35:11 Thu 22 15 8 16 12 8 10 67
16/01/2014 07:36 16-Jan-2014 07:36:11 Thu 19 14 8 16 13 8 9 68
16/01/2014 07:37 16-Jan-2014 07:37:11 Thu 17 15 8 18 14 9 9 67
16/01/2014 07:38 16-Jan-2014 07:38:11 Thu 17 15 9 16 14 8 9 65
16/01/2014 07:39 16-Jan-2014 07:39:11 Thu 16 15 8 17 14 9 9 65
16/01/2014 07:40 16-Jan-2014 07:40:11 Thu 16 14 8 16 14 8 9 65
16/01/2014 07:41 16-Jan-2014 07:41:11 Thu 16 14 8 16 13 8 9 65
16/01/2014 07:42 16-Jan-2014 07:42:11 Thu 16 14 8 16 13 9 9 67
16/01/2014 07:43 16-Jan-2014 07:43:11 Thu 16 14 9 17 13 8 8 67
16/01/2014 07:44 16-Jan-2014 07:44:11 Thu 15 14 8 16 13 8 8 67
16/01/2014 07:45 16-Jan-2014 07:45:11 Thu 16 14 8 16 13 8 8 68
16/01/2014 07:46 16-Jan-2014 07:46:11 Thu 15 13 8 17 13 8 8 70
16/01/2014 07:47 16-Jan-2014 07:47:11 Thu 15 13 8 18 13 8 8 69
16/01/2014 07:48 16-Jan-2014 07:48:11 Thu 15 13 8 18 13 8 8 69
16/01/2014 07:49 16-Jan-2014 07:49:11 Thu 15 13 8 18 12 8 8 70
16/01/2014 07:50 16-Jan-2014 07:50:11 Thu 15 13 8 15 12 9 9 66
16/01/2014 07:51 16-Jan-2014 07:51:11 Thu 14 12 8 15 10 8 9 64
16/01/2014 07:52 16-Jan-2014 07:52:11 Thu 14 13 8 14 11 8 9 62
16/01/2014 07:53 16-Jan-2014 07:53:11 Thu 14 12 8 15 12 8 9 60
16/01/2014 07:54 16-Jan-2014 07:54:11 Thu 14 12 8 15 12 8 9 58
16/01/2014 07:55 16-Jan-2014 07:55:11 Thu 14 12 8 15 13 8 9 56
16/01/2014 07:56 16-Jan-2014 07:56:11 Thu 14 13 9 15 12 9 9 55
16/01/2014 07:57 16-Jan-2014 07:57:11 Thu 14 13 8 15 12 8 8 54
16/01/2014 07:58 16-Jan-2014 07:58:11 Thu 14 13 8 14 12 8 8 52
16/01/2014 07:59 16-Jan-2014 07:59:11 Thu 14 13 8 15 12 8 8 51
16/01/2014 08:00 16-Jan-2014 08:00:11 Thu 14 13 9 8 50
16/01/2014 08:01 16-Jan-2014 08:01:11 Thu 15 13 8 15 11 8 9 50
16/01/2014 08:02 16-Jan-2014 08:02:11 Thu 15 12 8 9 49
16/01/2014 08:03 16-Jan-2014 08:03:11 Thu 14 13 8 15 11 8 9 48
16/01/2014 08:04 16-Jan-2014 08:04:11 Thu 14 13 8 15 12 8 9 48
16/01/2014 08:05 16-Jan-2014 08:05:11 Thu 15 13 8 15 12 8 9 47
16/01/2014 08:06 16-Jan-2014 08:06:11 Thu 14 12 8 15 13 8 9 45
16/01/2014 08:07 16-Jan-2014 08:07:11 Thu 14 13 8 9 44
16/01/2014 08:08 16-Jan-2014 08:08:11 Thu 15 13 8 14 11 8 9 42
16/01/2014 08:09 16-Jan-2014 08:09:11 Thu 14 13 8 14 11 8 9 42
16/01/2014 08:10 16-Jan-2014 08:10:11 Thu 14 13 8 9 41
16/01/2014 08:11 16-Jan-2014 08:11:11 Thu 14 12 8 14 11 8 9 40
16/01/2014 08:12 16-Jan-2014 08:12:11 Thu 19 18 11 18 16 10 9 42
16/01/2014 08:13 16-Jan-2014 08:13:11 Thu 18 17 10 18 16 10 10 48
16/01/2014 08:14 16-Jan-2014 08:14:11 Thu 18 16 9 18 16 9 10 50
16/01/2014 08:15 16-Jan-2014 08:15:11 Thu 18 16 10 17 15 9 10 53
16/01/2014 08:16 16-Jan-2014 08:16:11 Thu 17 16 9 17 15 9 11 47
16/01/2014 08:17 16-Jan-2014 08:17:11 Thu 17 15 9 17 15 9 12 46
16/01/2014 08:18 16-Jan-2014 08:18:11 Thu 17 15 8 17 15 8 12 46
16/01/2014 08:19 16-Jan-2014 08:19:11 Thu 17 15 8 17 14 8 12 45
16/01/2014 08:20 16-Jan-2014 08:20:11 Thu 17 15 8 17 15 8 12 45
16/01/2014 08:21 16-Jan-2014 08:21:11 Thu 17 15 8 17 14 8 12 44
16/01/2014 08:22 16-Jan-2014 08:22:11 Thu 17 15 8 17 14 8 12 43
16/01/2014 08:23 16-Jan-2014 08:23:11 Thu 17 15 8 12 43
16/01/2014 08:24 16-Jan-2014 08:24:11 Thu 17 15 8 17 14 8 11 47
16/01/2014 08:25 16-Jan-2014 08:25:11 Thu 18 17 8 18 16 9 10 49
16/01/2014 08:26 16-Jan-2014 08:26:11 Thu 18 16 8 18 16 8 10 52
16/01/2014 08:27 16-Jan-2014 08:27:11 Thu 18 16 8 18 15 8 10 53
16/01/2014 08:28 16-Jan-2014 08:28:11 Thu 17 16 8 17 15 8 12 48
16/01/2014 08:29 16-Jan-2014 08:29:11 Thu 17 16 8 18 15 8 12 47
RE: sequantial numbering
Format your data as a table. Select the range including the header and use command Insert/Table/My tables has headers = true.
From this table you can easily filter the data with spaces, 0 or 1.
RE776,
What blank things are you trying to ignore?
You do realize that a date is just a way to format a number in Excel. Your date should be the first cell. You can add decimals to the date and select a format that displays the time. You can add the time as the second cell, and select a nice looking time format.
CODE
42178.47292
6/23/2015
23-Jun-15
Tuesday, June 23, 2015
June 23, 2015
6/23/15 11:21 AM
6/23/15 11:21
J
J-15
The first cell contains =42178+11/24+21/(24*60)
I second IRstuff's suggestion. Add a column. Number the first row 1. The second row is row1+1. Copy this all the way down.
JHG
I am not sure I follow what is needed. Let us assume you want to sort with the information in one column but you want to neglect rows with blank data
Assume column A is the date you want to sort by and B and C have the data you don't want included after sorting if they are blank. Try a new column with:
=IF(OR(ISBLANK(B1),ISBLANK(C1)),"--",A1)
then sort the data by the new column and all of the valid data will be grouped together.
the row counters mentioned above (A2+1) work IF the cells are copy pasted as values (removing the equation).
the blanks i think are the entries with fewer numbers at the end of the record ... most have 8 numbers, some have fewer.
add the record counter column,
convert data record to a number of columns, (8 data? + 2 for date + 1 for record counter)
then scatter plot the record number column with a data column.
i think the missing data will plot as zero. if you really don't want zeros, copy the two columns (record counter and data) to another range, sort by data value (to collect the missing data) then sort the non-zero data by record counter and plot.
Quando Omni Flunkus Moritati
