How I can setup my catia v5 to have a finer resolution for STL files?
How can I setup my catia v5 to have a finer resolution for stl files when it's time to save catpart in STL format???
RE: How I can setup my catia v5 to have a finer resolution for STL files?
The only way I know how to change the number of triangles of an stl file is to change your visualtizaion.  If you go to Tools/Options/General/Display and select the Performance tab, you can change what your visulizaion accuracy is.  The better your 3D accuracy, the finer a mesh you will create.
Good luck!!
with Rapid Prototyping workbench, you can chose the sag you want for your STL output.
Have fun,
Eric
catiav5@softhome.net
