Bystronic Bystar 4020 btl 3000 display
Hello everybody,
Suddenly the display on the laser cabinet stopped working. The keypad is working but there is nothing on the display.
I'm starting up and working with the laser fine with a black screen.
Is it a way to test the display to see is it faulty? I took it out from the cabinet, but don't know how to test it.
Best regards,
Imre
Best regards,
Imre
RE: Bystronic Bystar 4020 btl 3000 display
If it has a 9 pin CGA connector, you would need an older PC with a VGA video card.
I am not very familiar with Bystronic, does it have a Fanuc Controller? They make LCD dropin replacements for Fanucs and many other controllers. Post pictures of your display and it's connectors if you can.
"I am stuck on Band-Aid brand, 'cause they are stuck on me"
Thanks for reply.
The model of the display is Futaba M402SD07GS.
It doesn't have a VGA/SVGA connector, it has pins and it is connected with the poscon pcb with a cable simmilar like
the serial bus in a pc just fewer pins.
Here is the specification from the dispaly.
Link
And is a picture
Thank you.
There is a DC to DC convertor, to get the required 5V, on the procon card.
Just make sure this is pumping out clean 5VDC, if not, throw in a new one.
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
