InfoWater Protector Vulnerability Results - "with Warnings"
Hello All,
I'm conducting several vulnerability analyses using InfoWater Protector and, while the overall results are in-line with my expectations, I am confused by a result of "with Warnings" that I receive in the Flow Conditions tab of the vulnerability report for ~1% of the pipes (very large model, translates to about 3000 pipes or so). It appears to be generated regardless of the Pass/Fail status of the pipe. I have manually "broken" a handful of these pipes in an effort to determine the cause of the message, but I can't seem to notice anything out of the ordinary (and no warnings are generated in the simulation log). The user's guide and help files make no mention of this.
Any insight would be greatly appreciated.
Thank you!
