NX 8.5 using subtract function
Hello all,
I was wondering how the subtract function works when cutting a ring around a sphere? The trick is, is that the ring needs to be altered 40 degrees in one direction and 20 degrees in another... I have attached a pic of the resulting line. I just don't know how they did it by using the subtract option....
RE: NX 8.5 using subtract function
If you know the axis about which the groove is to be revolved, then create the groove profile on a plane parallel to the axis of revolution and revolve the profile about that axis. Pretty simple, really.
Here's an example in NX8:
sphere_groove_nx8.prt
Tim Flater
NX Designer
NX 8.0.3.4
Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
I am not sure if I rotated the angles correctly, but you should get the message. I guessed on the sizes.
Maybe use feature playback to see better how I did it.
I used NX7.5
