Script - how to do it
Hi Guys,
I am trying to create a small script in Draftsight.
The script should delete everything inside the model space apart of one layer called for example "test"
Is there any chance to use a command line and do something like selectall aparat layer test
and then delete selected
or
select layer test
copy this
delete all
paste copied layer :)
Thank you.
Pawel
or
select layer test
copy this
delete all
Thank you.
Pawel
