NX9 spreadsheet Values from different parts
Hello
I have an assembly with different parts, each part has a lot of expressions, manly all expression values are measurements, so they don't drive anything.
Can I bring all these values from each part into the spreadsheet of the parent assembly file?
I only found how to bring the expressions to the spreadsheet from the part I'm using, not from other parts.
if I bring the expressions using the expression links, has to be 1 by 1 and they stop been associative. Also most expressions names are the same on each part so that wont work.
Thanks for your help
kiko
kiko
RE: NX9 spreadsheet Values from different parts
NX9 now has the option to bring all the expression from other parts into the expressions of the main assembly File.
It even gives you the option to add prefix or suffix to the expressions name.
Well done NX Team.
Thank you
