Unreinforced masonry with steel straps?
I have a project where the client is putting on an addition. The existing structure is believe to be unreinforced masonry infill (masonry cut in-between existing steel columns). Where the new building meets the existing building the client wants to remove 75% of the existing wall to provide access into the new structure. I have already briefed the client in regards to the possible implications of this (possibly requiring reinforcing of the remaining 25% of the wall). The architect however has suggested that we use steel straps attached to the face of the wall to help us solve our problem (I guess he has done this before). I said I would look into it to see if it was feasible. Has anyone done such a system before and if you have, what structural system would this fall under in ASCE 7-05?
RE: Unreinforced masonry with steel straps?
"Look for 3 things in a person intelligence, energy and integrity. If they don't have the last one, don't even bother with the first 2. W. Buffet
I'm not sure if the other engineer who worked on this architects project considered the straps reinforcing or not. I can't seem to find a system in ASCE 7-05 that would fit this description. Anything with straps mention is a light framed wall (metal studs).
Or are you suggesting vertical straps to create a sort of reinforced wall - replacing what should be vertical embedded reinforcement?
I'm not suggesting anything, the architect is suggesting based upon experience with a similar project he completed about 8 years ago. He was referencing horizontal and vertical members to take the place of reinforcing.
However,in my previous experience working for a steel fabricator, I seem to remember structures where the EOR used diagonal straps to reinforce the building.
BA
If a lateral system it doesn't sound worth it. Developing forces through masonry and also at the top and bottom will be tough and do you have to grout the ends or does it work as 1/4 the length unreinforced? Would it make more sense to remove 100% of masonry, add in a post at that 25% extent line, and use traditional bracing?
The other project that the architect is referencing could be completely different application. Maybe they saw someone add external plate reinforcing for out of plane loads and are trying to apply it here.
Mike McCann
MMC Engineering
