Unable to Edit sketch in NX-6
I am working in NX6. I have opened part that has sketch and some extrude on it. When I when double click on the sketch it went went to the sketch mode skech was no constrained and no dims in it. I tried to delete some curves in the sketch but they are not deleting even I used Trim option that also not worked. Let me know how can I edit or delete curves in the sketch.
thanks
thanks
RE: Unable to Edit sketch in NX-6
Is it an old file?
If it is so, you need to search (via Command Finder) for Pre-V13 Sketch.
