NFPA 70 NEC Article 225.30(E) Documented Switching Procedures
Apparently we have a situation where a documented switching procedure is required by 225.30(E). Does anyone have an example they could share? How detailed doe this have to be? Any insight would be appreciated.
I had posted this in the NFPA section but that was apparently not the correct forum so I am reposting it here.
RE: NFPA 70 NEC Article 225.30(E) Documented Switching Procedures
Thank you and that is what I thought. We got some clarification from the electrical inspector and what he is looking for is apparently LOTO procedures as he referenced NFPA 70E article 120.
