running journal from command prompt
Is it possible to run a journal (.vb) file from using batchcommand so I do not have to open the UG Gui. basically perform all the operations that I would like without opening the UG product?
thanks for the help
thanks for the help
RE: running journal from command prompt
If you have an author license, you can compile your journal to an .exe file, which can be run in batch mode.
www.nxjournaling.com
Home -> Fundamentals -> Recording NX sessions -> Journals -> Run a journal from the command prompt window.
