Pile set and Pile load test - Friction pile vs End Bearing pile
Can someone brief me the criteria of pile set and pile load test for friction pile and end bearing.Please correct me if im wrong as well.
Friction pile - no set taken during driving, wait for at least 2 weeks for dissipation of negative pore water pressure n mobilisation of the friction then conduct the static load test/PDA test.
ENd bearing - set taken during driving (based on Hiley formula), static load test could be conducted the very next day.
Any additional information that i should know or please correct me when im wrong. i'm here to learn.
RE: Pile set and Pile load test - Friction pile vs End Bearing pile
Mike Lambert
Yes i agree with you on the soil type.
However, do we still need to take final set for friction pile? For example, the pile will be terminated in medium dense sand not on rock.
