i created the border using sketch, how to hide the sketch procedure in the part navigator
the border option in nx8.5 is not the format we want, so i sketched the border myself
i saw some people's customed border and they dont have "sketch" procedure in the part navigator...
how to get rid of the sketch procedure?
thank you
http://files.engineering.com/getfile.aspx?folder=4...
RE: i created the border using sketch, how to hide the sketch procedure in the part navigator
You can't. It's hard to believe that the NX Border Creation function does NOT provide you with enough flexibility to get a usable Drawing border. I'd go back and try it again...
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Hi john,
But I do have a template drawing whose border doe not look like Siemens border, it doesn't have sketch procedure but in the layer setting, I do see all lines are in one layer which is 211
here is my drawing template, the left lower corner starts with A which is different from NX border, any comments?
problem solved, thank you very much!!!!!!!!!!
i need to to be more careful...
Use File- Export- CGM and export the border.
Delete the Sketch.
File - Import - CGM and import the border.
The imported border will be non-parametric, non associative objects.
exactly as a drawing border should be...
Regards.
Tomas
