Autodesk Simulation Mechanical: Analysis Failed
New to this program.
I am trying to run an old thermal analysis created by my predecessor, and it fails after few seconds of running. There is a note "Analysis Failed" next to design scenario name, and no more info.
How I can look at what's wrong?
Could not find anything in Help.
Boris.
RE: Autodesk Simulation Mechanical: Analysis Failed
If you look in that folder you should see a bunch of files with a recent creation date, which are actually text files. If you are lucky one is called .log, have a read of that.
Cheers
Greg Locock
No luck, no log file. Any other places?
Boris.
How to turn on log files? For SCR=NO, where should I type it?
Boris.
