Change from ISO std to ANSI std dimensions.
I have a drawing/model that is showing the ISO std dimension when I do an ordinate dimension on the drawing. Where do I set or change this so that the ordinate dimension is in an ANSI std format. I don't want the ordinate to show the arrow that I've circled which is per ISO std. Thanks.
RE: Change from ISO std to ANSI std dimensions.
I answered my own question on how to turn the arrow off. Had the SHOW DIMENSION LINE ticked on under the Ordinate set.
