Blower Inlet Transition Size Question
I am retrofitting a replacement blower to an existing ring dryer to accommodate some increased airflow requirements. I have calculated the system static and flow requirements and have selected a blower that matches. (38" WC at 18,000 CFM) The question I have is regarding the inlet flange (suction side) on the blower which is 30" ID, vs the existing duct size which is 20". I wasn't sure if there were any issues with fabricating a transition piece to match these dimensions. The manufacture has recommended a 10X diameter length of the transition to minimize any system effects, and otherwise says would not be an issue with airflow or otherwise.
Other fans I considered met the same requirements but had the fan inlet ranging at 21" - 23" ID, but these were significantly more costly, so I would like to use the other unit with the larger inlet.
Just thought I would get a sanity check from anyone with more experience than I on this. Thanks.
RE: Blower Inlet Transition Size Question
