Allwable lateral defelction of stud walls and wind columns
Is there any Code or Standard that specifies the maximum allowable lateral deflection of wood stud walls and wood columns under wind load, where the wall has a brittle finish such as plaster or gypsum board (drywall)? I would have thought that the limit would be L/360, but to my surprise that limit seems to be only for live load on floors/roofs supporting plaster ceilings, and not for wind loads on walls and wind columns, at least as far as I can find in the National Building Code of Canada, and CSA 086.1 "Engineering Design in Wood". I am particularly interested in wood at the moment.
RE: Allwable lateral defelction of stud walls and wind columns
L/240 for other brittle finishes
L/120 for flexible finishes
this is due to snow or wind load.
