NX9 - Assign Material
Is there a "quick start" guide for setting up a SITE material library ?
NX 6.0.5.3, NX 9.0.2.5
NX 10 (Testing)
Windows 7 64 (Windows 8.1 Tablet)
RE: NX9 - Assign Material
> Home > CAE > Advanced Simulation > Materials
...and there will be information about defining and editing material data.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Using Customer Defaults, at Site level, I've specified a Directory of MatML files for a Site Library and entered the folder location.
I restarted NX.
When I go to assign a material, my "local" library isn't available ?
NX 10 (Testing)
However, I now need to edit some of the materials in the Library. Problem is, I can't figure out how to edit the materials. The docs refer to "From the Type list, select Edit Library Material." I don't have this option, only "Export".
Can anyone help ?
NX 9.0.3.4
NX 10 (Testing)
Hello. I'm Kajetan
I have the same problem. I exported my materials to a MatML.xml file. In Customer Settings I set a path to MatML.xml file. After restarting program my materials aren't available.
How did you solve this problem?
For myself, I may have had to specify the path explicitly in the dialog.
NX 9.0.3.4
NX 10 (Testing)
