what is laser pulse shaping?
And how can I change the pulse shaping in a laser machine independent of machine itself. Meaning that I do have a laser machine that doesn't allow me to vary laser pulse shaping, can I use any kind of mirror to connect to it in order to change the pulse shaping?
thanks
thanks
RE: what is laser pulse shaping?
TTFN
Why are you trying to shape the pulse?
Dan - Owner
http://www.Hi-TecDesigns.com
Pulsed lasers typically have Q switches and there is voltage shaping that can be done to the switching voltage to modify the pulse, but for short pulses, there's not much that can really be done, since everything is running at its maximum speed already. Any pulse that's short relative to the laser resonator path length is pretty much fixed.
TTFN
Dan, I am trying to change pulse shaping since I need to investigate how change in pulse shaping affects my samples.
How in general pulse shaping affects the laser? does it increases the power delivered?
thanks again in advance
Energy is conserved, but generally, any perturbation tends to reduce output energy.
TTFN
Timelord
Dan - Owner
