Constraints turn black in Assembly Design
I have two parts in Assembly Design in an overlay and I need to make changes to one of the parts but it's hard to work with because the constraints have turned black instead of the usual green or white. Can someone tell me whats happening here and hopefully what I can do to fix it?
RE: Constraints turn black in Assembly Design
if this is the case, you have to edit the constraint and use logic to solve the problem.
you can change the unresolved color in tools/option/general/ Parameters and measure // Constraints and Dimension tab
______
Alex ,
